venus-os:gx-gsm
venus-os:gx-gsm [2019-10-03 16:30] – [5. Trouble shooting] mvader | venus-os:gx-gsm [2019-10-03 20:54] – Accessory section linked krenzke | ||
Line 25: | Line 25: | ||
* GSM900200100 - Active GPS Antenna for GX GSM | * GSM900200100 - Active GPS Antenna for GX GSM | ||
- | See bottom of this manual for photos and specs of both optional antennas. | + | [[venus-os: |
==== Compatibility ==== | ==== Compatibility ==== | ||
Line 78: | Line 78: | ||
- | ===== 6. GPS ===== | + | ===== 5. GPS ===== |
When the optional antenna is added; the position will be visible like this: | When the optional antenna is added; the position will be visible like this: | ||
Line 87: | Line 87: | ||
- | ===== 5. Trouble shooting ===== | + | ===== 6. Trouble shooting ===== |
Whilst usually working well, in case the modem does not connect to the internet it can one of many reasons. Carefully go through each step of this trouble shooting guide, starting at the first. | Whilst usually working well, in case the modem does not connect to the internet it can one of many reasons. Carefully go through each step of this trouble shooting guide, starting at the first. | ||
Line 107: | Line 107: | ||
- | ===== 6. Supported Frequencies (2G/3G) ===== | + | ===== 7. Supported Frequencies (2G/3G) ===== |
* 2G (GSM/ | * 2G (GSM/ | ||
Line 119: | Line 119: | ||
In case of uncertainty please double-check: | In case of uncertainty please double-check: | ||
- | ===== 7. Technical Data ===== | + | ===== 8. Technical Data ===== |
^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ||
Line 129: | Line 129: | ||
^ SIM card | Regular Mini SIM | | ^ SIM card | Regular Mini SIM | | ||
- | ===== 8. Accessory / Antennas ===== | + | ===== 9. Accessory / Antennas ===== |
==== Outdoor 2G and 3G GSM Antenna ==== | ==== Outdoor 2G and 3G GSM Antenna ==== | ||
