venus-os:gx-gsm
venus-os:gx-gsm [2019-10-03 13:42] – [5. Trouble shooting] mvader | venus-os:gx-gsm [2020-06-24 13:53] – [1.4 When to use a mobile router instead] mvader | ||
Line 5: | Line 5: | ||
- | The GX GSM is an accessory for [[venus-os: | + | ==== 1.1 Product description ==== |
- | It requires a SIM card of the [[https:// | + | The GX GSM is an accessory for [[venus-os: |
+ | It requires a SIM card of the [[https:// | ||
See also the [[https:// | See also the [[https:// | ||
Line 15: | Line 17: | ||
{{youtube> | {{youtube> | ||
- | === Antennas and accessories === | + | ==== 1.2 Antennas and accessories |
GSM: A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna: | GSM: A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna: | ||
Line 25: | Line 27: | ||
* GSM900200100 - Active GPS Antenna for GX GSM | * GSM900200100 - Active GPS Antenna for GX GSM | ||
- | See bottom of this manual for photos and specs of both optional | + | [[venus-os: |
- | ==== Compatibility ==== | + | ==== 1.3 Compatibility ==== |
The GX GSM can be used with any of the [[venus-os: | The GX GSM can be used with any of the [[venus-os: | ||
The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. | The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. | ||
- | The GX GSM only provides an internet connection for the [[venus-os: | + | ==== 1.4 When to use a mobile router instead ==== |
+ | The GX GSM provides an internet connection for the [[venus-os: | ||
For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https:// | For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https:// | ||
Line 68: | Line 71: | ||
- | ===== 4. Status ===== | + | |
+ | ===== 4. GPS ===== | ||
+ | When the optional antenna is added; the position will be visible like this: | ||
+ | Also the position is sent to the [[https:// | ||
+ | ===== 5. Status ===== | ||
+ | ==== Status Bar ==== | ||
GSM modem status can be checked at a glance by looking at the status bar. | GSM modem status can be checked at a glance by looking at the status bar. | ||
^ Icon ^ Details ^ | ^ Icon ^ Details ^ | ||
Line 78: | Line 93: | ||
- | ===== 6. GPS ===== | + | ==== SIM Status |
+ | ^ Status ^ Description ^ | ||
+ | | Ready | SIM card is installed properly and registered to the network | | ||
+ | | SIM not inserted | SIM card is missing or not inserted properly. SIM tray might hang out a little. | | ||
+ | | PIN required | SIM card requires 4 digit PIN for unlock. | | ||
+ | | PUK required | SIM is locked due to wrong PIN inputs. 8 digit PUK is required to release the lock state. | | ||
+ | | SIM failure | SIM does not respond - might be broken | | ||
+ | | SIM busy | SIM is in busy state | | ||
+ | | SIM wrong | Type of SIM is not supported | | ||
- | When the optional antenna is added; the position will be visible like this: | + | [[http:// |
- | {{: | + | There are many reasons for modem internet connection to not work. Carefully go through each step of this trouble shooting guide. Make sure to start at the first step. When asking for help, make sure to mention each step taken and the result. |
- | Also the position | + | ^ Step ^^ Details |
+ | | 1 | Power | Check that the blue LED is either lit continuous or blinking | ||
+ | | 2 | USB connection | ||
+ | | 3 | Simcard status | Check the SIM Status in the menu, it must show " | ||
+ | | 4 | Signal strength | 1 bar minimum for VRM logging, 2 or 3 bars are necessary for a working remote console | | ||
+ | | 5 | Carrier registration | Check that a name of a Cellular provider is visible in the " | ||
+ | | 6 | Internet connection | Verify that the Internet shows " | ||
+ | | 7 | Connection to VRM Portal | Verify that the VRM Portal menu shows a recent last connection time. See Settings -> VRM Portal. For more details, see [[https://www.victronenergy.com/ | ||
+ | An [[venus-os: | ||
- | ===== 5. Trouble shooting ===== | + | Note that Ethernet and WiFi connections have priority over the cellular connection. Even when the available Ethernet |
- | Whilst usually working well, in case the modem does not connect to the internet it can one of many reasons. Carefully go through each step of this trouble shooting guide, starting at the first. | + | This screenshot shows how all details look when everything is OK: |
- | ^ Step ^^ Details | + | {{:venus-os:gsm-settings-full.png? |
- | | 1 | Check power | Check that the blue LED is either lit continuous or blinking | + | |
- | | 2 | Check USB connection | + | |
- | | 3 | Simcard status | Check the SIM Status in the menu, it must show " | + | |
- | | 4 | Signal strength | 1 bar minimum for VRM logging, 2 or 3 bars are necessary for a working remote console | | + | |
- | | 5 | Network registration | Check that a network name is visible. If it is not, check signal strength and otherwise contact your simcard provider and/or insert the simcard in a phone to double check its operation and subscription status. | | + | |
- | | 6 | Internet connection | Verify that the Internet shows " | + | |
- | | 7 | Connection to VRM Portal | Verify that the VRM Portal menu shows a recent last connection time. See Settings | + | |
- | An outdoor antenna typically increases received signal by 15 dB to 25 dB. | + | ===== 7. Supported Frequencies (2G/3G) ===== |
- | ===== 6. Supported Frequencies (2G/3G) ===== | + | ==== 7.1 Available models & their supported frequency bands ==== |
+ | GSM100100100 - GX GSM 900/2100: | ||
* 2G (GSM/ | * 2G (GSM/ | ||
* 3G (UMTS/ | * 3G (UMTS/ | ||
+ | * The used GSM module is a Simcom SIM5360E. | ||
- | Please notice: In Northern | + | GSM100200100 - GX GSM 850/1900: |
+ | * 2G (GSM/ | ||
+ | * 3G (UMTS/ | ||
+ | * The used GSM module is the Simcom SIM5360A. | ||
+ | * Expected in first stock in 2020 Q3. And only short lived; since its successor, the GX LTE 4G, having 2G/3G and also 4G support is also coming soon. | ||
+ | ==== 7.2 Notes regarding regional coverage ==== | ||
+ | USA, Mexico, Canada and most of South America: 1900 MHz is the most common frequency for 3G, which is unsupported for the current version of GX GSM. But a second model is coming in 2020, see above. | ||
+ | Australia: The 900MHz 3G frequency in remote areas is typically provided by Optus. Telstra' | ||
In case of uncertainty please double-check: | In case of uncertainty please double-check: | ||
- | ===== 7. Technical Data ===== | + | |
+ | ===== 8. Technical Data ===== | ||
^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ||
Line 120: | Line 157: | ||
^ SIM card | Regular Mini SIM | | ^ SIM card | Regular Mini SIM | | ||
- | ===== 8. Accessory / Antennas ===== | + | ===== 9. Accessory / Antennas ===== |
==== Outdoor 2G and 3G GSM Antenna ==== | ==== Outdoor 2G and 3G GSM Antenna ==== | ||
