venus-os:gx-gsm [2019-10-03 13:42] – [5. Trouble shooting] mvader | venus-os:gx-gsm [2020-01-18 11:23] – [7. Supported Frequencies (2G/3G)] mvader |
* GSM900200100 - Active GPS Antenna for GX GSM | * GSM900200100 - Active GPS Antenna for GX GSM |
See bottom of this manual for photos and specs of both optional antennas. | [[venus-os:gx-gsm#accessory_antennas|See bottom of this manual for photos and specs of both optional antennas.]] |
==== Compatibility ==== | ==== Compatibility ==== |
{{:venus-os:gsm-apn-config.png?direct&480|}} | {{:venus-os:gsm-apn-config.png?direct&480|}} |
===== 4. Status ===== | |
GSM modem status can be checked at a glance by looking at the status bar. | |
^ Icon ^ Details ^ | ===== 4. GPS ===== |
| {{:venus-os:gsm-status-signalstrength.png?nolink&27}} | GSM modem is connected to network, but not to the internet (no data connection). Either on purpose, because an ethernet or WiFi connection is available. | | |
| {{:venus-os:gsm-status-gsm-internet.png?nolink&48|}} | GSM modem is properly configured, the 3G/E/etc icon reflects that the GSM modem internet connection is in use. | | |
| {{:venus-os:gsm-status-gsm-plus-wifi.png?nolinkx&54|}} | WiFi is available and its internet connection is in use. WiFi has priority over GSM. | | |
| {{:venus-os:gsm-status-pin-required.png?nolink&27|}} | SIM PIN code is required. | | |
| {{:venus-os:gsm-status-roaming.png?nolink&27|}} | Roaming, only informative. To use internet connection while roaming it needs to be enabled in \\ Settings -> GSM modem -> Allow roaming. | | |
===== 6. GPS ===== | |
When the optional antenna is added; the position will be visible like this: | When the optional antenna is added; the position will be visible like this: |
===== 5. Trouble shooting ===== | ===== 5. Status ===== |
Whilst usually working well, in case the modem does not connect to the internet it can one of many reasons. Carefully go through each step of this trouble shooting guide, starting at the first. | ==== Status Bar ==== |
| | {{:venus-os:gsm-status-signalstrength.png?nolink&27}} | GSM modem is connected to network, but not to the internet (no data connection).\\ Either on purpose, because an ethernet or WiFi connection is available. | |
| ==== SIM Status ==== |
| ^ Status ^ Description ^ |
| | Ready | SIM card is installed properly and registered to the network | |
| | SIM not inserted | SIM card is missing or not inserted properly. SIM tray might hang out a little. | |
| | PIN required | SIM card requires 4 digit PIN for unlock. | |
| | PUK required | SIM is locked due to wrong PIN inputs. 8 digit PUK is required to release the lock state. | |
| | SIM failure | SIM does not respond - might be broken | |
| | SIM busy | SIM is in busy state | |
| | SIM wrong | Type of SIM is not supported | |
| [[http://example.com|External Link]]===== 6. Trouble shooting ===== |
| There are many reasons for modem internet connection to not work. Carefully go through each step of this trouble shooting guide. Make sure to start at the first step. When asking for help, make sure to mention each step taken and the result. |
^ Step ^^ Details ^ | ^ Step ^^ Details ^ |
| 1 | Check power | Check that the blue LED is either lit continuous or blinking | | | 1 | Power | Check that the blue LED is either lit continuous or blinking | |
| 2 | Check USB connection | The modem must be connected to USB, and visible in the Settings -> GSM modem menu | | | 2 | USB connection | The modem must be connected to USB, and visible in the Settings -> GSM modem menu | |
| 3 | Simcard status | Check the SIM Status in the menu, it must show "Ready". It will show "SIM not inserted", or "PIN required", or "PUK required" and more related errors when there is a problem. | | | 3 | Simcard status | Check the SIM Status in the menu, it must show "Ready". It will show "SIM not inserted", or "PIN required", or "PUK required" and more related errors when there is a problem. Please refer to the [[venus-os:gx-gsm#sim_status|SIM Status list]] for details. | |
| 4 | Signal strength | 1 bar minimum for VRM logging, 2 or 3 bars are necessary for a working remote console | | | 4 | Signal strength | 1 bar minimum for VRM logging, 2 or 3 bars are necessary for a working remote console | |
| 5 | Network registration | Check that a network name is visible. If it is not, check signal strength and otherwise contact your simcard provider and/or insert the simcard in a phone to double check its operation and subscription status. | | | 5 | Carrier registration | Check that a name of a Cellular provider is visible in the "Carrier" field. If it is not, check signal strength and otherwise contact your simcard provider and/or insert the simcard in a phone to double check its operation and subscription status. | |
| 6 | Internet connection | Verify that the Internet shows "Online". Reasons for the system to not go "Online" whilst properly registered on the Network are: 1) APN not configured, contact the network operator for details. 2) The network is a different one than the home network (ie. roaming), and the setting to permit Roaming is disabled. 3) Signal strength is strong enough to register on the network, but not to open the data connection to the internet. 4) The GX Device is already connected to Ethernet or WiFi: they have priority over the cellular connection. | | | 6 | Internet connection | Verify that the Internet shows "Online". Reasons for the system to not go "Online" whilst properly registered on the Network are:\\ 1) APN not configured, contact the network operator for details.\\ 2) The network is a different one than the home network (ie. roaming), and the setting to permit Roaming is disabled.\\ 3) Signal strength is strong enough to register on the network, but not to open the data connection to the internet. | |
| 7 | Connection to VRM Portal | Verify that the VRM Portal menu shows a recent last connection time. See Settings -> VRM Portal. For more details, see [[https://www.victronenergy.com/live/ccgx:start#trouble_shooting_data_logging|the VRM Connection troubleshooting chapter of the GX Manual]]. | | | 7 | Connection to VRM Portal | Verify that the VRM Portal menu shows a recent last connection time. See Settings -> VRM Portal. For more details, see [[https://www.victronenergy.com/live/ccgx:start#trouble_shooting_data_logging|the VRM Connection troubleshooting chapter of the GX Manual]]. | |
An outdoor antenna typically increases received signal by 15 dB to 25 dB. | An [[venus-os:gx-gsm#accessory_antennas|outdoor antenna]] typically increases received signal by 15 dB to 25 dB. |
===== 6. Supported Frequencies (2G/3G) ===== | Note that Ethernet and WiFi connections have priority over the cellular connection. Even when the available Ethernet or WiFi connection does **not** have a good connection to the internet. There is **no** automatic detection in place which in such case switches over to the GX GSM. In more technical language: when the cellular data connection is active, it is configured with a high routing metric. This way, the Linux kernel prioritises Ethernet or Wifi when these are available. |
| This screenshot shows how all details look when everything is OK: |
| {{:venus-os:gsm-settings-full.png?direct&480|}} |
| ===== 7. Supported Frequencies (2G/3G) ===== |
| GX GSM, part number GSM100100100: |
* 2G (GSM/GPRS/EDGE): 850/900/1800/1900 MHz (Quad-Band) | * 2G (GSM/GPRS/EDGE): 850/900/1800/1900 MHz (Quad-Band) |
* 3G (UMTS/HSPA+): 900/2100 MHz (Dual-Band) | * 3G (UMTS/HSPA+): 900/2100 MHz (Dual-Band) |
| * The used module is a Simcom SIM5360E. |
| A second model is coming, expected in 2020 Q3, having below frequencies, suitable for the common networks in Mexico, USA & Canada as well as various countries in Southern America. |
| * 2G (GSM/GPRS/EDGE): 850/900/1800/1900 MHz (Quad-Band) - same between both models. |
| * 3G (UMTS/HSPA+): 850/1900 MHz (Dual-Band) |
| * This new product will be based on the Simcom SIM5360A. |
| ==== Regional Coverage Information ==== |
| USA, Mexico, Canada and most of South America: 1900 MHz is the most common frequency for 3G, which is unsupported for the current version of GX GSM. But a second model is coming in 2020, see above. |
Please notice: In Northern America 1900 MHz is the most common frequency for 3G, which is unsupported for the current version of GX GSM. | Australia: The 900MHz 3G frequency in remote areas is typically provided by Optus. Telstra's rural 3G network operates at 850MHz which is not supported with the current version of GX GSM. Both Telstra and Optus operate 2100Mhz networks in urban areas, and are supported. |
In case of uncertainty please double-check: [[https://www.worldtimezone.com/gsm.html|GSM World Coverage Map]] | In case of uncertainty please double-check: [[https://www.worldtimezone.com/gsm.html|GSM World Coverage Map]] |
===== 7. Technical Data ===== | ===== 8. Technical Data ===== |
^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https://www.victronenergy.de/upload/documents/GX-GSM-Dimensions.pdf|Drawing]]) | | ^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https://www.victronenergy.de/upload/documents/GX-GSM-Dimensions.pdf|Drawing]]) | |
^ SIM card | Regular Mini SIM | | ^ SIM card | Regular Mini SIM | |
===== 8. Accessory / Antennas ===== | ===== 9. Accessory / Antennas ===== |
==== Outdoor 2G and 3G GSM Antenna ==== | ==== Outdoor 2G and 3G GSM Antenna ==== |
{{:venus-os:gsm900100100.png?nolink&250 |}} | {{:venus-os:gsm900100100.png?nolink&250 |}} |
