venus-os:gx-gsm
venus-os:gx-gsm [2019-05-01 16:54] – [6. Supported Frequencies (2G/3G)] krenzke | venus-os:gx-gsm [2019-06-16 20:20] – [1. Introduction] mvader | ||
Line 5: | Line 5: | ||
- | The GX GSM is an accessory for [[venus-os: | + | The GX GSM is an accessory for [[venus-os: |
- | It requires a SIM card of the [[https:// | + | It requires a SIM card of the [[https:// |
See also the [[https:// | See also the [[https:// | ||
+ | Video explaining how to connect using LAN, WiFi, and the GX GSM: | ||
+ | {{youtube> | ||
=== Antennas and accessories === | === Antennas and accessories === | ||
Line 25: | Line 29: | ||
==== Compatibility ==== | ==== Compatibility ==== | ||
+ | The GX GSM can be used with any of the [[venus-os: | ||
* Color Control GX | * Color Control GX | ||
* Venus GX | * Venus GX | ||
* Octo GX | * Octo GX | ||
- | The GX GSM requires Venus OS v2.22 or newer to be installed on the [[venus-os: | + | The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. |
==== When to use a mobile router instead ==== | ==== When to use a mobile router instead ==== | ||
- | The GX GSM only provides an internet connection for the [[venus-os: | + | The GX GSM only provides an internet connection for the [[venus-os: |
For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https:// | For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https:// |
