venus-os:gx-gsm
venus-os:gx-gsm [2019-01-22 10:43] – external edit 127.0.0.1 | venus-os:gx-gsm [2019-05-01 16:54] – [6. Supported Frequencies (2G/3G)] krenzke | ||
Line 97: | Line 97: | ||
You also need to remember that an outdoor antenna typically increases received signal by 15 dB to 25 dB. (verify) | You also need to remember that an outdoor antenna typically increases received signal by 15 dB to 25 dB. (verify) | ||
- | ===== 6. Technical Data ===== | + | ===== 6. Supported Frequencies (2G/3G) ===== |
+ | * 2G (GSM/ | ||
+ | * 3G (UMTS/ | ||
+ | Please notice: In Northern America 1900 MHz is the most common frequency for 3G, which is unsupported for the current version of GX GSM. | ||
+ | In case of uncertainty please double-check: | ||
+ | ===== 7. Technical Data ===== | ||
^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ||
Line 107: | Line 115: | ||
^ SIM card | Regular Mini SIM | | ^ SIM card | Regular Mini SIM | | ||
- | ===== 7. Accessory / Antennas ===== | + | ===== 8. Accessory / Antennas ===== |
==== Outdoor 2G and 3G GSM Antenna ==== | ==== Outdoor 2G and 3G GSM Antenna ==== | ||
