venus-os:gx-gsm
venus-os:gx-gsm [2019-01-06 20:51] – [1. Introduction] mvader | venus-os:gx-gsm [2019-06-13 10:35] – [When to use a mobile router instead] jcecil | ||
Line 5: | Line 5: | ||
- | The GX GSM is an accessory for [[venus-os: | + | The GX GSM is an accessory for [[venus-os: |
- | It requires a SIM card of the [[https:// | + | It requires a SIM card of the [[https:// |
See also the [[https:// | See also the [[https:// | ||
Line 25: | Line 25: | ||
==== Compatibility ==== | ==== Compatibility ==== | ||
+ | The GX GSM can be used with any of the [[venus-os: | ||
* Color Control GX | * Color Control GX | ||
* Venus GX | * Venus GX | ||
* Octo GX | * Octo GX | ||
- | The GX GSM requires Venus OS v2.22 or newer to be installed on the [[venus-os: | + | The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. |
==== When to use a mobile router instead ==== | ==== When to use a mobile router instead ==== | ||
- | The GX GSM only provides an internet connection for the [[venus-os: | + | The GX GSM only provides an internet connection for the [[venus-os: |
For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https:// | For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https:// | ||
Line 97: | Line 97: | ||
You also need to remember that an outdoor antenna typically increases received signal by 15 dB to 25 dB. (verify) | You also need to remember that an outdoor antenna typically increases received signal by 15 dB to 25 dB. (verify) | ||
- | ===== 6. Technical Data ===== | + | ===== 6. Supported Frequencies (2G/3G) ===== |
+ | * 2G (GSM/ | ||
+ | * 3G (UMTS/ | ||
+ | Please notice: In Northern America 1900 MHz is the most common frequency for 3G, which is unsupported for the current version of GX GSM. | ||
+ | In case of uncertainty please double-check: | ||
+ | ===== 7. Technical Data ===== | ||
^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ||
Line 107: | Line 115: | ||
^ SIM card | Regular Mini SIM | | ^ SIM card | Regular Mini SIM | | ||
- | ===== 7. Accessory / Antennas ===== | + | ===== 8. Accessory / Antennas ===== |
==== Outdoor 2G and 3G GSM Antenna ==== | ==== Outdoor 2G and 3G GSM Antenna ==== | ||
Line 127: | Line 135: | ||
^ Frequency | 1575.42 MHz | | ^ Frequency | 1575.42 MHz | | ||
^ Impedance | 50 Ω | | ^ Impedance | 50 Ω | | ||
