venus-os:gx-gsm
venus-os:gx-gsm [2018-08-27 11:30] – jperez | venus-os:gx-gsm [2023-01-19 09:47] (current) – Deleted. A new manual has been added to the product page. sloges | ||
- | ====== GX GSM ====== | ||
- | DRAFT: function & product not released yet. | ||
- | ===== 1. Introduction ===== | ||
- | The GX GSM is an accessory for Venus-devices. It is a cellular modem; providing a mobile internet connection for the system. | ||
- | It requires a SIM card; and connects to the Venus-device with a (supplied) ??m USB cable. | ||
- | A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna. (Add partnumber; and somewhere there must be a picture of it and specs, GX GSM datasheet!? | ||
- | ==== GPS ==== | ||
- | Besides internet, the GX GSM also has a GPS receiver. To use that, buy the optional active GSM antenna. (Add part number) | ||
- | ==== Compatibility ==== | ||
- | * Color Control GX | ||
- | * Venus GX | ||
- | * Octo GX | ||
- | The GX GSM requires Venus OS v2.20 or newer to be installed on the Venus-device. | ||
- | The GX GSM only provides an internet connection for the Venus-device: | ||
- | For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. More information here (link to proper chapter in Ccgx manual). | ||
- | ===== 2. Installation ===== | ||
- | Mount the device an connect the antenna. Consider using the outdoor antenna when installing the GX GSM in a closed metal enclosure. | ||
- | Insert the SIM card. | ||
- | Connect the GX GSM to the Venus device with the supplied USB cable. Use a USB hub in case all USB sockets are already in use. | ||
- | Connect DC power supply (8 to 70 VDC). | ||
- | ===== 3. Configuration ===== | ||
- | When using a SIM card with its SIM-pin security disabled, the system will work without further configuration. Verify operation by .. ? (Check VRM Last log data?) | ||
- | Setting a SIM pin helps reducing the risk of the SIM card being stolen and used. Use a mobile phone to set the SIM pin, and there after configure it on the Venus device. | ||
- | Settings -> GSM modem -> PIN code | ||
- | Some mobile networks require manual configuration of an APN specially when roaming. Contact your operator. | ||
- | APN name can be configured in Settings -> GSM Modem -> APN. | ||
- | ===== 4. Status ===== | ||
- | GSM modem status can be checked at a glance by looking at the status bar. | ||
- | ^ Icon ^ Details ^ | ||
- | ===== 5. Trouble shooting ===== | ||
- | ^ ^ Step | ||
- | | 1 | Power | Check that the blue LED is either lit continuous or blinking | ||
- | | 2 | USB | The modem must be connected to USB, and visible in the Settings -> GSM modem menu | | ||
- | | 3 | Simcard | If enabled, PIN code must be configured in Settings -> GSM modem -> PIN | | ||
- | | 4 | Signal strength | 1 bar for VRM logging, 2/3 bars for remote console | | ||
- | | 5 | Network | Check that a network name is visible. If it is not, contact your simcard provider and/or insert the simcard in a phone to double check its operation.| | ||
- | You also need to remember that an outdoor antenna typically increases received signal by 15 dB to 25 dB. (verify) | ||
