venus-os:gx-gsm
venus-os:gx-gsm [2018-11-21 13:13] – [6. Technical Data] krenzke | venus-os:gx-gsm [2022-01-06 11:35] – mvader | ||
- | ====== GX GSM ====== | + | ====== GX GSM manual |
- | DRAFT: function & product not released yet. | + | |
- | The GX GSM is an accessory for Venus-devices. It is a cellular modem; providing a mobile internet for the system and connection to Victron Remote Management (VRM). | ||
- | It requires a full sized SIM card; and connects to the Venus-device with a (supplied) 1m USB cable. | + | ==== 1.1 Product description ==== |
- | A small indoor | + | The GX GSM is an accessory for [[venus-os:start|GX-devices]]. It is a cellular 2G and 3G modem; providing a mobile internet for the system and connection to [[https:// |
- | !!!! Somewhere there must be a picture | + | It requires |
- | ==== GPS ==== | + | |
- | Besides internet, | + | |
- | {{:venus-os:gps-settings-full.png? | + | |
- | ==== Compatibility ==== | + | |
- | * Color Control GX | + | See also the [[https:// |
- | * Venus GX | + | |
- | * Octo GX | + | |
- | The GX GSM requires Venus OS v2.20 or newer to be installed on the Venus-device. | + | Video explaining how to connect using LAN, WiFi, and the GX GSM: |
- | ==== When to use a mobile router instead ==== | + | {{youtube> |
- | The GX GSM only provides an internet connection for the Venus-device: there is no option to share the internet to laptops, phones, or other devices. | + | ==== 1.2 Warning: maybe use the GX LTE 4G instead ==== |
+ | The product described in this manual, is being succeeded with the newer [[https:// | ||
+ | The GX GSM works only with 2G and 3G networks, which are -slowly- being shut down in various countries. Hence, depending on the location of installation, | ||
+ | ==== 1.4 Antennas and accessories ==== | ||
+ | GSM: A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna: | ||
+ | * GSM900100100 - Outdoor 2G and 3G GSM Antenna for GX GSM | ||
+ | GPS: The unit has a built-in GPS receiver. An antenna is not included; to use the GPS received; purchase the GPS Antenna. | ||
+ | * GSM900200100 - Active GPS Antenna for GX GSM | ||
+ | [[venus-os: | ||
+ | ==== 1.5 GX Compatibility ==== | ||
+ | The GX GSM can be used with any of the [[venus-os: | ||
+ | The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. | ||
+ | ==== 1.6 When to use a mobile router instead ==== | ||
+ | The GX GSM provides an internet connection for the [[venus-os:start|GX-device]] only. There is no option to share the internet to laptops, phones, or other devices. | ||
For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https:// | For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https:// | ||
===== 2. Installation ===== | ===== 2. Installation ===== | ||
Mount the device and connect the antenna. Consider using the outdoor antenna when installing the GX GSM in a closed metal enclosure. | Mount the device and connect the antenna. Consider using the outdoor antenna when installing the GX GSM in a closed metal enclosure. | ||
- | Insert the SIM card. You will need to eject the SIM card tray with a pen or other pointy object. Be aware that the SIM card try sits slightly recessed inside the unit. Be sure to push it all the way in. | + | Insert the SIM card. You will need to eject the SIM card tray with a pen or other pointy object. Be aware that the SIM card tray sits slightly recessed inside the unit. Be sure to push it all the way in. |
- | Connect the GX GSM to the Venus device with the supplied USB cable. Use a USB hub if all USB sockets are already in use. | + | Connect the GX GSM to the GX-device with the supplied USB cable. Use a USB hub if all USB sockets are already in use. |
Connect DC power supply (8 to 70 VDC). A 1.4M wire is included, with M10 lugs and an inline fuse. | Connect DC power supply (8 to 70 VDC). A 1.4M wire is included, with M10 lugs and an inline fuse. | ||
After power-up, the blue LED will be solid blue. Next, once it has registered on a network, it will start blinking slowly. Finally, when it has established the internet connection, it will be blinking fast. | After power-up, the blue LED will be solid blue. Next, once it has registered on a network, it will start blinking slowly. Finally, when it has established the internet connection, it will be blinking fast. | ||
- | When using a SIM card with its SIM-pin security disabled, the system will work without further configuration. | + | When using a SIM card with its SIM-pin security disabled, the system will work without further configuration. |
- | Setting a SIM pin helps reducing the risk of the SIM card being stolen and used. Use a mobile phone to set the SIM pin, and there after configure it on the Venus device. | + | Setting a SIM pin helps reducing the risk of the SIM card being stolen and used. Use a mobile phone to set the SIM pin, and there after configure it on the GX-device. |
Settings -> GSM modem -> PIN code | Settings -> GSM modem -> PIN code | ||
Line 57: | Line 77: | ||
- | ===== 4. Status ===== | + | **Automatic recovery when disconnected** |
+ | When installing the GX GSM, or GX 4G LTE in an area that you expect continuous internet coverage, you should enable the " | ||
+ | Note that if you are leaving internet service coverage areas (such as an RV on the move, or a boat leaving dock to go to sea) then it is recommend to disable this setting, so that your GX is not rebooting itself for no reason. Or set it, for example, to a two hour time-out. And accept a reboot every two hours when underway. | ||
+ | ===== 4. GPS ===== | ||
+ | When the optional antenna is added; the position will be visible like this: | ||
+ | Also the position is sent to the [[https:// | ||
+ | ===== 5. Status ===== | ||
+ | ==== Status Bar ==== | ||
GSM modem status can be checked at a glance by looking at the status bar. | GSM modem status can be checked at a glance by looking at the status bar. | ||
^ Icon ^ Details ^ | ^ Icon ^ Details ^ | ||
+ | ==== SIM Status ==== | ||
+ | ^ Status ^ Description ^ | ||
+ | | Ready | SIM card is installed properly and registered to the network | | ||
+ | | SIM not inserted | SIM card is missing or not inserted properly. SIM tray might hang out a little. | | ||
+ | | PIN required | SIM card requires 4 digit PIN for unlock. | | ||
+ | | PUK required | SIM is locked due to wrong PIN inputs. 8 digit PUK is required to release the lock state. | | ||
+ | | SIM failure | SIM does not respond - might be broken | | ||
+ | | SIM busy | SIM is in busy state | | ||
+ | | SIM wrong | Type of SIM is not supported | | ||
- | ===== 5. Trouble shooting ===== | + | [[http:// |
+ | ===== 6. Trouble shooting ===== | ||
- | ^ | + | There are many reasons for modem internet connection to not work. Carefully go through each step of this trouble shooting guide. Make sure to start at the first step. When asking for help, make sure to mention each step taken and the result. |
+ | ^ Step ^^ Details | ||
| 1 | Power | Check that the blue LED is either lit continuous or blinking | | 1 | Power | Check that the blue LED is either lit continuous or blinking | ||
- | | 2 | USB | The modem must be connected to USB, and visible in the Settings -> GSM modem menu | | + | | 2 | USB connection |
- | | 3 | Simcard | If enabled, PIN code must be configured in Settings | + | | 3 | Simcard |
- | | 4 | Signal strength | 1 bar for VRM logging, 2/3 bars for remote console | | + | | 4 | Signal strength | 1 bar minimum |
- | | 5 | Network | + | | 5 | Carrier registration |
+ | | 6 | Internet connection | Verify that the Internet shows " | ||
+ | | 7 | Connection to VRM Portal | Verify that the VRM Portal menu shows a recent last connection time. See Settings -> VRM Portal. For more details, see [[https:// | ||
+ | An [[venus-os: | ||
+ | Note that Ethernet and WiFi connections have priority over the cellular connection. Even when the available Ethernet | ||
+ | This screenshot shows how all details look when everything is OK: | ||
+ | === What to do if the GX GSM is not staying connected? === | ||
+ | Enable the " | ||
+ | ===== 7. Supported Frequencies (2G/3G) ===== | ||
+ | ==== 7.1 Available models & their supported frequency bands ==== | ||
+ | GSM100100100 - GX GSM 900/2100: | ||
+ | * 2G (GSM/ | ||
+ | * 3G (UMTS/ | ||
+ | * The used GSM module is a Simcom SIM5360E. | ||
+ | GSM100200100 - GX GSM 850/1900: | ||
+ | * 2G (GSM/ | ||
+ | * The used GSM module is the Simcom SIM5360A. | ||
+ | * Expected in first stock in 2020 Q3. And only short lived; since its successor, the GX LTE 4G, having 2G/3G and also 4G support is also coming soon. | ||
+ | ==== 7.2 Notes regarding regional coverage ==== | ||
+ | USA, Mexico, Canada and most of South America: 1900 MHz is the most common frequency for 3G, which is unsupported for the current version of GX GSM. But a second model is coming in 2020, see above. | ||
+ | Australia: The 900MHz 3G frequency in remote areas is typically provided by Optus. Telstra' | ||
- | You also need to remember that an outdoor antenna typically increases received signal by 15 dB to 25 dB. | + | In case of uncertainty please double-check: |
- | ===== 6. Technical Data ===== | + | ===== 8. Technical Data ===== |
^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ||
Line 89: | Line 176: | ||
^ SIM card | Regular Mini SIM | | ^ SIM card | Regular Mini SIM | | ||
- | ===== 7. Accessory / Antennas ===== | + | ===== 9. Accessory / Antennas ===== |
- | ====Outdoor 2G and 3G GSM Antenna | + | ==== Outdoor 2G and 3G GSM Antenna ==== |
+ | ^ Part number | GSM900100100 | | ||
^ Mounting option | Screw Mount | | ^ Mounting option | Screw Mount | | ||
^ Cable Type | Rg-316 | | ^ Cable Type | Rg-316 | | ||
Line 99: | Line 187: | ||
^ Signal Gain | 3 dbi | | ^ Signal Gain | 3 dbi | | ||
- | ====Active GPS Antenna | + | ==== Active GPS Antenna ==== |
+ | ^ Part number | GSM900200100 | | ||
^ Mounting option | Magnet | | ^ Mounting option | Magnet | | ||
^ Cable Type | Rg-174 | | ^ Cable Type | Rg-174 | |
