venus-os:extended
venus-os:extended [2020-06-17 00:11] – [Appendix A - Repartitioning Venus GX flash memory] mvader | venus-os:extended [2020-10-19 16:00] – [5.4 First use & configuring] pbu | ||
- | ====== Venus OS Extended | + | ====== Venus OS Large image: Signal K and Node-RED ====== |
(DRAFT - THIS DOCUMENT IS ABOUT NOT YET COMPLETELY FINISHED FUNCTIONALITY) | (DRAFT - THIS DOCUMENT IS ABOUT NOT YET COMPLETELY FINISHED FUNCTIONALITY) | ||
Line 5: | Line 5: | ||
- | This manual documents the extended | + | This manual documents the " |
Line 35: | Line 35: | ||
===== 2. Where to find support ===== | ===== 2. Where to find support ===== | ||
- | There is and will be no official support on the functionalities included in this image. For support, turn to the [[https:// | + | There is and will be **no official support** on the functionalities included in this image. For support, turn to the [[https:// |
===== 3. Requirements ===== | ===== 3. Requirements ===== | ||
+ | ==== 3.1 GX Device compatibility ==== | ||
A compatible GX device: | A compatible GX device: | ||
Line 49: | Line 51: | ||
Venus OS extended is also available for certain RaspberryPi models. Installation files below, and installation & other raspberrypi specific instructions [[https:// | Venus OS extended is also available for certain RaspberryPi models. Installation files below, and installation & other raspberrypi specific instructions [[https:// | ||
+ | ==== 3.2 CPU & Memory resources ==== | ||
+ | Both SignalK as well as Node-red are rather resource intensive software applications to run on the GX Device. From a CPU usage point of view as well as RAM memory. | ||
+ | Ofcourse, how intensive depends on what kind of flows (node-red) or how many messages & handling of them (SignalK) happens in the system. | ||
+ | From a GX device point of view, from the support models the Venus GX is the one with the least resources. Running both SignalK and Node-RED at the same time will be " | ||
+ | Cerbo GX is already much faster, as it has a dual core CPU as well as much more RAM. | ||
+ | More details about CPU & RAM differences are in this document: https:// | ||
+ | When running out of RAM or CPU, the device will slow down. And eventually also reboot by itself due to the watchdog. | ||
===== 3. How to install ===== | ===== 3. How to install ===== | ||
Line 195: | Line 211: | ||
Open a web browser, and go to the SignalK Dashboard by navigating to http:// | Open a web browser, and go to the SignalK Dashboard by navigating to http:// | ||
- | Further documentation about that is ... (some link to singalk-node documentation? | + | Further documentation about that is ... (some link to signalk-node documentation? |
=== Step 2. Configure serial connections === | === Step 2. Configure serial connections === | ||
Line 241: | Line 257: | ||
+ | ===== 6. Remote access via VRM ===== | ||
+ | ==== 6.1 Node-RED flow editor and Signal K ==== | ||
+ | It it possible to access Node-RED flow editor and Signal K remotely via VRM - the interface and functionality is identical to access via LAN (ie. via **http:// | ||
+ | === Step by step instructions === | ||
+ | * **Step 1.** Log into/open the regular VRM ' | ||
+ | * **Step 2.** Modify the URL to include **/proxy/** after the site URL ID number (note that the last **/** is required) | ||
+ | As an example: **https:// | ||
+ | * **Step 3.** Click on the **Node-RED** or **Signal K** button in the Proxy relay screen; depending on location and the speed of internet connection, there may be a short delay while loading | ||
+ | * **Step 4.** The Node-RED flow editor or Signal K interface screen will appear | ||
+ | ==== 6.2 Node-RED Dashboard/ | ||
+ | It it also possible to access the Node-RED dashboard/ | ||
+ | * **Step 1.** Follow steps #1 to 4 in section 6.1 above in order to ' | ||
+ | * **Step 2.** The ' | ||
+ | * **Step 3.** The Node-RED dashboard/ | ||
===== Appendix A - Repartitioning Venus GX flash memory ===== | ===== Appendix A - Repartitioning Venus GX flash memory ===== |
venus-os/extended.txt · Last modified: 2021-01-06 22:04 by mvader
