venus-os:extended
venus-os:extended [2020-05-16 13:06] – [3. How to install] mvader | venus-os:extended [2020-05-25 13:50] – [4.2 Installing extra nodes] mvader | ||
Line 57: | Line 57: | ||
* **Step 2.** Disable Auto updates. See Settings -> Firmware -> Online updates in Remote Console. | * **Step 2.** Disable Auto updates. See Settings -> Firmware -> Online updates in Remote Console. | ||
* **Step 3.** Download the latest Venus-OS Extended image from the last comments on [[https:// | * **Step 3.** Download the latest Venus-OS Extended image from the last comments on [[https:// | ||
+ | * **Step 4.** Install that file using the [[ccgx: | ||
+ | * **Step 5.** Verify that the image was successfully installed: go to Settings -> Services, and check that Signal K and Node-RED are now available to enable. | ||
+ | * **Step 6.** Enable either Signal K or Node-RED. Note that though its possible to enable both, doing so on a Venus GX is " | ||
+ | * **Finished**. The Venus OS Extended image has now been installed successfully. Continue in either the Node-RED or the Signal K chapter below. | ||
=== Special note for the RaspberryPi === | === Special note for the RaspberryPi === | ||
Line 95: | Line 99: | ||
Make sure that there is always 30MB of free space remaining on the data partition. TODO: how can a user see that? Also mem usage / mem free & some cpu stats would be nice to see. Maybe with a dashboard & flow? ;o) | Make sure that there is always 30MB of free space remaining on the data partition. TODO: how can a user see that? Also mem usage / mem free & some cpu stats would be nice to see. Maybe with a dashboard & flow? ;o) | ||
+ | ==== 4.3 Controlling relays ==== | ||
+ | === GX Device relays === | ||
+ | Controllable, | ||
+ | === MPPT Relay === | ||
+ | Note that while there is a Victron node that offers to control the relay in a solar charger (only large solar chargers have a relay!), its currently not workable since VictronConnect does not offer the required " | ||
+ | === BMV Relay === | ||
+ | Currently not possible, the driver in Venus OS doesn' | ||
+ | === Multi & Quattro Relays === | ||
+ | Includes alarm relays as well as the AC-out 2 relay: its not possible to control those; and there is no plan to make them controllable from within Node-RED. | ||
===== 5. Signal K ===== | ===== 5. Signal K ===== | ||
Line 207: | Line 225: | ||
Plugging it into the GX Device will make it be recognised automatically; | Plugging it into the GX Device will make it be recognised automatically; | ||
- | __NMEA2000 | + | __NMEA2000 |
+ | Connect it to the GX Device on the canbus port. Consider using our '' | ||
- | Connect it to the GX Device on the canbus port. Consider using our VE.Can to NMEA2000 | + | In Venus OS v2.60, support for NMEA2000 |
- | Since v2.60, Venus OS will pickup GPS data from the canbus === | + | Signal K can then get it in two ways: directly from the NMEA2000 canbus in case thats configured as a data provider in Signal K. And via the native |
- | But SignalK will pick it up. | + | Conclusion (untested), when using a NMEA2000 GPS, it will be available to both Venus OS and Signal K. |
- | There is no way (yet) to share it from within SignalK to Venus OS; and therefor it also will not be available to use on the VRM Portal. | ||
__Part of a NMEA0183 network__ | __Part of a NMEA0183 network__ | ||
- | Tbd. | + | Tbd. Actually a NMEA0183-network is probably something that doesnt exist: you can't have NMEA0183 in a network, its point to point. |
venus-os/extended.txt · Last modified: 2021-01-06 22:04 by mvader
