venus-os:extended
venus-os:extended [2020-05-16 13:06] – [3. How to install] mvader | venus-os:extended [2020-10-19 16:00] – [5.4 First use & configuring] pbu | ||
- | ====== Venus OS Extended | + | ====== Venus OS Large image: Signal K and Node-RED ====== |
(DRAFT - THIS DOCUMENT IS ABOUT NOT YET COMPLETELY FINISHED FUNCTIONALITY) | (DRAFT - THIS DOCUMENT IS ABOUT NOT YET COMPLETELY FINISHED FUNCTIONALITY) | ||
Line 5: | Line 5: | ||
- | This manual documents the extended | + | This manual documents the " |
Line 35: | Line 35: | ||
===== 2. Where to find support ===== | ===== 2. Where to find support ===== | ||
- | There is and will be no official support on the functionalities included in this image. For support, turn to the [[https:// | + | There is and will be **no official support** on the functionalities included in this image. For support, turn to the [[https:// |
===== 3. Requirements ===== | ===== 3. Requirements ===== | ||
+ | ==== 3.1 GX Device compatibility ==== | ||
A compatible GX device: | A compatible GX device: | ||
Line 49: | Line 51: | ||
Venus OS extended is also available for certain RaspberryPi models. Installation files below, and installation & other raspberrypi specific instructions [[https:// | Venus OS extended is also available for certain RaspberryPi models. Installation files below, and installation & other raspberrypi specific instructions [[https:// | ||
+ | ==== 3.2 CPU & Memory resources ==== | ||
+ | Both SignalK as well as Node-red are rather resource intensive software applications to run on the GX Device. From a CPU usage point of view as well as RAM memory. | ||
+ | Ofcourse, how intensive depends on what kind of flows (node-red) or how many messages & handling of them (SignalK) happens in the system. | ||
+ | From a GX device point of view, from the support models the Venus GX is the one with the least resources. Running both SignalK and Node-RED at the same time will be " | ||
+ | Cerbo GX is already much faster, as it has a dual core CPU as well as much more RAM. | ||
+ | More details about CPU & RAM differences are in this document: https:// | ||
+ | When running out of RAM or CPU, the device will slow down. And eventually also reboot by itself due to the watchdog. | ||
===== 3. How to install ===== | ===== 3. How to install ===== | ||
Line 57: | Line 73: | ||
* **Step 2.** Disable Auto updates. See Settings -> Firmware -> Online updates in Remote Console. | * **Step 2.** Disable Auto updates. See Settings -> Firmware -> Online updates in Remote Console. | ||
* **Step 3.** Download the latest Venus-OS Extended image from the last comments on [[https:// | * **Step 3.** Download the latest Venus-OS Extended image from the last comments on [[https:// | ||
+ | * **Step 4.** Install that file using the [[ccgx: | ||
+ | * **Step 5.** Verify that the image was successfully installed: go to Settings -> Services, and check that Signal K and Node-RED are now available to enable. | ||
+ | * **Step 6.** Enable either Signal K or Node-RED. Note that though its possible to enable both, doing so on a Venus GX is " | ||
+ | * **Finished**. The Venus OS Extended image has now been installed successfully. Continue in either the Node-RED or the Signal K chapter below. | ||
=== Special note for the RaspberryPi === | === Special note for the RaspberryPi === | ||
Line 67: | Line 87: | ||
The Node-RED editor is at http:// | The Node-RED editor is at http:// | ||
+ | The username is " | ||
==== 4.1 Introduction ==== | ==== 4.1 Introduction ==== | ||
Line 95: | Line 115: | ||
Make sure that there is always 30MB of free space remaining on the data partition. TODO: how can a user see that? Also mem usage / mem free & some cpu stats would be nice to see. Maybe with a dashboard & flow? ;o) | Make sure that there is always 30MB of free space remaining on the data partition. TODO: how can a user see that? Also mem usage / mem free & some cpu stats would be nice to see. Maybe with a dashboard & flow? ;o) | ||
+ | ==== 4.3 Controlling relays ==== | ||
+ | === GX Device relays === | ||
+ | Controllable, | ||
+ | === MPPT Relay === | ||
+ | Note that while there is a Victron node that offers to control the relay in a solar charger (only large solar chargers have a relay!), its currently not workable since VictronConnect does not offer the required " | ||
+ | === BMV Relay === | ||
+ | Currently not possible, the driver in Venus OS doesn' | ||
+ | === Multi & Quattro Relays === | ||
+ | Includes alarm relays as well as the AC-out 2 relay: its not possible to control those; and there is no plan to make them controllable from within Node-RED. | ||
===== 5. Signal K ===== | ===== 5. Signal K ===== | ||
Line 177: | Line 211: | ||
Open a web browser, and go to the SignalK Dashboard by navigating to http:// | Open a web browser, and go to the SignalK Dashboard by navigating to http:// | ||
- | Further documentation about that is ... (some link to singalk-node documentation? | + | Further documentation about that is ... (some link to signalk-node documentation? |
=== Step 2. Configure serial connections === | === Step 2. Configure serial connections === | ||
Line 207: | Line 241: | ||
Plugging it into the GX Device will make it be recognised automatically; | Plugging it into the GX Device will make it be recognised automatically; | ||
- | __NMEA2000 | + | __NMEA2000 |
- | Connect it to the GX Device on the canbus port. Consider using our VE.Can to NMEA2000 cable to go from Micro-C to RJ-45. | + | Connect it to the GX Device on the canbus port. Consider using our '' |
- | Since v2.60, | + | In Venus OS v2.60, |
- | But SignalK will pick it up. | + | Signal K can then get it in two ways: directly from the NMEA2000 canbus in case thats configured as a data provider in Signal K. And via the native Venus OS functionality through the Victron-signalk-plugin. |
+ | Conclusion (untested), when using a NMEA2000 GPS, it will be available to both Venus OS and Signal K. | ||
- | There is no way (yet) to share it from within SignalK to Venus OS; and therefor it also will not be available to use on the VRM Portal. | ||
__Part of a NMEA0183 network__ | __Part of a NMEA0183 network__ | ||
- | Tbd. | + | Tbd. Actually a NMEA0183-network is probably something that doesnt exist: you can't have NMEA0183 in a network, its point to point. |
+ | ===== 6. Remote access via VRM ===== | ||
+ | ==== 6.1 Node-RED flow editor and Signal K ==== | ||
+ | It it possible to access Node-RED flow editor and Signal K remotely via VRM - the interface and functionality is identical to access via LAN (ie. via **http:// | ||
+ | === Step by step instructions === | ||
+ | * **Step 1.** Log into/open the regular VRM ' | ||
+ | * **Step 2.** Modify the URL to include **/proxy/** after the site URL ID number (note that the last **/** is required) | ||
+ | As an example: **https:// | ||
+ | * **Step 3.** Click on the **Node-RED** or **Signal K** button in the Proxy relay screen; depending on location and the speed of internet connection, there may be a short delay while loading | ||
+ | * **Step 4.** The Node-RED flow editor or Signal K interface screen will appear | ||
+ | ==== 6.2 Node-RED Dashboard/ | ||
+ | It it also possible to access the Node-RED dashboard/ | ||
+ | * **Step 1.** Follow steps #1 to 4 in section 6.1 above in order to ' | ||
+ | * **Step 2.** The ' | ||
+ | * **Step 3.** The Node-RED dashboard/ | ||
===== Appendix A - Repartitioning Venus GX flash memory ===== | ===== Appendix A - Repartitioning Venus GX flash memory ===== | ||
The Venus GX has sufficient flash memory to run the Venus OS Extended image. But up until end of 2018 it was produced with a partition layout not suitable to run large versions of Venus OS. This appendix explains how to self update the partitions to the new format. | The Venus GX has sufficient flash memory to run the Venus OS Extended image. But up until end of 2018 it was produced with a partition layout not suitable to run large versions of Venus OS. This appendix explains how to self update the partitions to the new format. | ||
- | Perform this procedure only when connected via Ethernet. Do not use the built-in WiFi AP to performing this procedure. The AP will not work half way the procedure. | + | |
+ | Perform this procedure only when connected via Ethernet | ||
+ | Do not use the built-in WiFi AP to performing this procedure. The AP will not work half way the procedure. Similarly, any WiFi (client-) configuration will be wiped after running the installer. Therefore, as said, make sure to be able to connect on the LAN port before starting this procedure. | ||
**WARNING**: | **WARNING**: | ||
Line 294: | Line 360: | ||
Side info: see here for more details on installing an image. | Side info: see here for more details on installing an image. | ||
- | Once done, reboot the device, | + | Once done, reboot the device. |
+ | After the boot (30 to 60 seconds) the LED will be slow blinking green. Indicating that the WiFi access point is off (as expected). More information about the LED operation is in the Venus GX manual. | ||
+ | Now, re-obtain yourself root access to continue. Note that all settings will be wiped by the installer: | ||
+ | * you'll need to go to Remote Console on LAN, then change access level again, enable ssh, change root password, and then login. | ||
+ | * As warned above, you’ll need to do this on the LAN port. The built-in WiFi access-point will be disabled, and any previously configured WiFi (client-) configuration will be lost as the installer will have wiped all settings. | ||
=== Step D. Restore the files === | === Step D. Restore the files === | ||
Line 307: | Line 379: | ||
ssh 192.168.178.122 reboot | ssh 192.168.178.122 reboot | ||
+ | Once completed, the WiFi access point will be operational again. | ||
=== Step E. Install extended Venus OS === | === Step E. Install extended Venus OS === | ||
Now, the Venus GX has been repartitioned, | Now, the Venus GX has been repartitioned, |
venus-os/extended.txt · Last modified: 2021-01-06 22:04 by mvader
