venus-os:canvu-gx
venus-os:canvu-gx [2018-11-13 17:40] – created guy_stewart | venus-os:canvu-gx [2020-05-13 11:20] (current) – mvader | ||
- | The CANvu GX is a forthcoming | + | ====== CANvu GX Manual ====== |
+ | The CANvu GX is a product in the Victron [[venus-os: | ||
+ | The CANvu GX is a device similar to the Color Control GX, and most of it's functionality and features are explained in the Color Control Manual here : https:// | ||
+ | **CANvu GX:** | ||
+ | * Data Logger & Control Functions | ||
+ | * Item IP67 All Round Protection | ||
+ | * USB connection | ||
+ | **CANvu GX IO Extender and wiring kit:** | ||
+ | Note; this kit needs to be purchased separately and is always needed. Included in the kit is: | ||
+ | * CANvu GX IO extender | ||
+ | * Power cable (supply voltage 8 - 32 VDC, **48V systems REQUIRE a suitable power supply or **[[https:// | ||
+ | * VE.Can cable | ||
+ | * Ethernet cable | ||
+ | Features: | ||
+ | * VE.CAN bus connections | ||
+ | * CAN bus connections not isolated | ||
+ | * VE.Bus connection | ||
+ | * 3x VE.Direct connection | ||
+ | * 1 Analogue input | ||
+ | * 1 Digital input | ||
+ | * 1 Relay output | ||
+ | * 1 Ethernet Port | ||
+ | Overview of connections | ||
venus-os/canvu-gx.1542127253.txt.gz · Last modified: 2018-11-13 17:40 by guy_stewart
