venus-os:canvu-gx
venus-os:canvu-gx [2019-01-22 10:43] – external edit 127.0.0.1 | venus-os:canvu-gx [2019-07-16 09:25] – guy_stewart | ||
- | The CANvu GX is a forthcoming | + | The CANvu GX is a product in the Victron [[venus-os: |
+ | The CANvu GX is a device similar to the Color Control GX, and most of it's functionality and features are explained in the Color Control Manual here : https:// | ||
Line 6: | Line 8: | ||
* Data Logger & Control Functions | * Data Logger & Control Functions | ||
* Item IP67 All Round Protection | * Item IP67 All Round Protection | ||
+ | * USB connection | ||
**CANvu GX IO Extender and wiring kit:** | **CANvu GX IO Extender and wiring kit:** | ||
+ | Note; this kit needs to be purchased separately and is always needed. Included in the kit is: | ||
+ | * CANvu GX IO extender | ||
+ | * Power cable (supply voltage 8 - 32 VDC, **48V systems REQUIRE a suitable power supply or **[[https:// | ||
+ | * VE.Can cable | ||
+ | * Ethernet cable | ||
Features: | Features: | ||
- | * CANbus Connections | + | * VE.CAN bus connections |
- | * VE.Bus | + | * CAN bus connections not isolated |
+ | * VE.Bus | ||
* 3x VE.Direct connection | * 3x VE.Direct connection | ||
- | * 1x Analogue, 1x Digital | + | * 1 Analogue |
- | * 1x Ethernet Port | + | * 1 Digital |
- | + | * 1 Relay output | |
- | {{: | + | * 1 Ethernet Port |
+ | Overview of connections | ||
venus-os/canvu-gx.txt · Last modified: 2020-05-13 11:20 by mvader
