venus-gx:start
venus-gx:start [2019-02-09 00:06] – [4.1. Wiring details] guy_stewart | venus-gx:start [2019-04-17 14:44] – [3.2 Small button located to the right of the green 14-Terminal Connector Block] mvader | ||
Line 2: | Line 2: | ||
- | In many ways the **Venus GX (VGX)** and the **Color Control GX (CCGX)** are the same device. They share a lot of hardware, and they run on identical software - our 'Venus OS' - therefore firmware numbering is the same; and new version releases always apply to both devices at the same time. | + | In many ways the **Venus GX (VGX)** and the **Color Control GX (CCGX)** are the same device. They share a lot of hardware, and they run on identical software - our 'Venus OS' - therefore firmware numbering is the same; and new version releases always apply to both devices at the same time. |
+ | As many of the functions of the two devices are identical, the [[ccgx: | ||
This manual refers to the latest firmware version. A device connected to the internet will perform new-version updates automatically. Check the latest firmware version [[https:// | This manual refers to the latest firmware version. A device connected to the internet will perform new-version updates automatically. Check the latest firmware version [[https:// | ||
Line 103: | Line 105: | ||
==== 3.2 Small button located to the right of the green 14-Terminal Connector Block==== | ==== 3.2 Small button located to the right of the green 14-Terminal Connector Block==== | ||
- | This button | + | This button |
+ | There are no other functions | ||
===== 4. Digital Inputs ===== | ===== 4. Digital Inputs ===== |
