vedirect_protocol:faq
vedirect_protocol:faq [2020-07-20 14:18] – [Q8: How do I calculate the TEXT checksum?] mbosma | vedirect_protocol:faq [2021-01-20 19:51] – [1. FAQ] mvader | ||
====== VE.Direct Protocol FAQ ====== | ====== VE.Direct Protocol FAQ ====== | ||
More information on the VE.Direct protocol is available here: | More information on the VE.Direct protocol is available here: | ||
Line 6: | Line 7: | ||
* [[open_source: | * [[open_source: | ||
- | Note that, besides | + | Note that, besides |
- | ===== 1. FAQ ===== | + | From a hardware point of view, our VE.Direct ports have four pins: positive, TX, RX and GND. The TX and RX go (almost) directly into the UART of the microcontroller of the product. |
+ | To connect directly to such port, we advise to use either our VE.Direct to USB interface, or our VE.Direct to RS232 interface. Both include galvanic isolation circuitry. Having such isolation is important, as in the product itself (ie. in the solar charger, bmv battery monitor, inverter and so forth) there is very little protection. | ||
+ | More information, | ||
+ | ===== 2. FAQ ===== | ||
==== Q1: Can I use RS232 instead of USB? ==== | ==== Q1: Can I use RS232 instead of USB? ==== | ||
Yes, use the //VE.Direct to RS232 interface//, | Yes, use the //VE.Direct to RS232 interface//, | ||
Line 79: | Line 87: | ||
==== Q8: How do I calculate the TEXT checksum? ==== | ==== Q8: How do I calculate the TEXT checksum? ==== | ||
- | I need to get data from a BMV, but do I check the data integrity? The [[https:// | + | I need to get data from a BMV, but how do I check the data integrity? The [[https:// |
**Answer: | **Answer: |
vedirect_protocol/faq.txt · Last modified: 2023-03-31 12:04 by mvader
