vedirect_lorawan
vedirect_lorawan [2019-01-21 11:20] – [7. DISQUS] ictbeheer | vedirect_lorawan [2019-10-02 10:23] – removed the content and added a link to docs lasse | ||
- | ===== 1. Introduction ===== | + | This manual |
- | Thank you for purchasing a [[https:// | + | |
- | * [[https:// | + | |
- | ===== 2. LoRaWAN radio frequencies and coverage ===== | + | |
- | The VE.Direct LoRaWAN (Long Range wide area network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron installation) to a nearby Internet of Things (IoT) gateway. The gateway should be within about 2km of your location if you live in a town, but could be as far away as 30km if you live in a rural location. | + | |
- | You can even expand the IoT infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred Euro' | + | |
- | ==== 2.1 Recommended LoRaWAN gateways ==== | + | |
- | * https:// | + | |
- | ==== 2.2 Bandwidth and frequencies ==== | + | |
- | Note that whilst it's free to use, and long range, LoRaWAN is not high bandwidth. Therefore data is only sent once an hour ...some less important data is only sent once every 24 hours. (See below for more information.) | + | |
- | Frequencies used by the LoRaWAN module differ by region and country. We stock two different versions: | + | |
- | * ASS030538010 - VE.Direct LoRaWAN EU863-870 module | + | |
- | * ASS030540010 - VE.Direct LoRaWAN US902-928 module | + | |
- | * ASS030542010 - VE.Direct LoRaWAN AU915-928 module (expected Dec 2017 or Jan 2018) | + | |
- | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. [[https:// | + | |
- | ===== 3. Product compatibility ===== | + | |
- | This module | + | |
- | * All [[https:// | + | |
- | The module is not compatible with our **Peak Power Packs** - even though they have a VE.Direct Port. | + | |
- | More information is also available on our website: https:// | + | |
- | ===== 4. Installation ===== | + | |
- | What's in the box?: | + | |
- | * VE.Direct LoRaWAN module, with 1.5m VE.Direct cable | + | |
- | * Antenna | + | |
- | * 1.5m power cable with 3A inline fuse and M10 eyelets. | + | |
- | * Quick-install guide | + | |
- | Assembly instructions: | + | |
- | - Screw the antenna onto the LoRaWAN Module | + | |
- | - Mount the LoRaWAN Module close to the device you wish to monitor | + | |
- | - Connect the VE.Direct cable between devices | + | |
- | - Connect the DC Power (8V - 68V) | + | |
- | - After a short wait the LED will blink green indicating that all is OK | + | |
- | - Go to the [[https://vrm.victronenergy.com/ | + | |
- | ===== 5. Details ===== | + | |
- | === Data transmission ==== | + | |
- | After this first transmission, | + | |
- | __ BMV Battery Monitor__ | + | |
- | * Battery Voltage | + | |
- | * Battery Current | + | |
- | * Battery Power | + | |
- | * State of Charge | + | |
- | * Alarm status & reason | + | |
- | __MPPT Solar Charger__ | + | |
- | * Solar Power | + | |
- | * Error code (see [[mppt-error-codes|here]] for the definitions) | + | |
- | * Charge state (Off, Bulk, Absorption, Equalize, Float) | + | |
- | __Phoenix VE.Direct Inverters__ | + | |
- | * AC Output current | + | |
- | * Mode (On/ | + | |
- | Note that data may not always arrive at the VRM Portal every hour. Transmission over the air can fail - even when your LoRaWAN device is mounted close to a gateway. This is normal and part of the LoRaWAN concept. | + | |
- | === LED Codes === | + | |
- | ^ LED Status ^ Definition ^ | + | |
- | | Blinking blue | Connecting to LoRaWAN. If your module keeps blinking blue, check LoRaWAN Network coverage. | | + | |
- | | Blinking green | Everything is OK and a connection has been made both to LoRaWAN and to the VE.Direct device. | | + | |
- | | Blinking yellow | You're connected to LoRaWAN, but not to the VE.Direct device: Check the cable & power to the VE.Direct device. | | + | |
- | | Continuous red | Error. The module will automatically reboot within ten seconds. | | + | |
- | === Current draw === | + | |
- | * 15 mA @ 12V | + | |
- | * 8,5 mA @ 24V | + | |
- | * 5,5 mA @ 48V | + | |
- | ===== 6. FAQ ===== | + | |
- | //Will the module store data and send it out later when the gateway is in range?// | + | |
- | *No. | + | |
- | *No. | + | |
- | //How can I connect multiple VE.Direct devices to one LoRaWAN module?// | + | |
- | *You can' | + | |
- | *No you can' | + | |
- | //Can the module be used to remotely switch the load output of an MPPT?// | + | |
- | *No. | + | |
- | *No. | + | |
- | //Can the module be used to remotely change the configuration of the BMV, MPPT or Inverter?// | + | |
- | *No. | + | |
- | *No. | + | |
- | *No. | + | |
+ | ~~DISQUS~~ | ||
