vebus_smart_dongle_manual
vebus_smart_dongle_manual [2019-02-22 12:38] – [Introduction] guy_stewart | vebus_smart_dongle_manual [2019-06-24 14:54] – Moved system requirements to the top of the manual jpasop | ||
====== VE.Bus Smart Dongle - manual ====== | ====== VE.Bus Smart Dongle - manual ====== | ||
- | Work in progress. This page contains input for the user manual | ||
+ | ===== System requirements ===== | ||
+ | **Multi firmware versions before 415 are not supported** | ||
+ | ^ Function | ||
+ | | Battery voltage and temperature sense | 419 | | | ||
+ | | Input current limit and on/ | ||
Line 51: | Line 58: | ||
- Plug the connector block into the dongle. | - Plug the connector block into the dongle. | ||
- Connect the dongle to the Multi' | - Connect the dongle to the Multi' | ||
- | ===== System requirements ===== | ||
- | **Multi firmware versions before 415 are not supported** | ||
- | ^ Function | ||
- | | Battery voltage and temperature sense | 419 | | | ||
- | | Input current limit and on/ | ||
===== LED Status codes ===== | ===== LED Status codes ===== |
vebus_smart_dongle_manual.txt · Last modified: 2022-09-13 14:44 by stefanie
