vebus_smart_dongle_manual
vebus_smart_dongle_manual [2019-06-21 16:13]
mvader [VE.Bus Smart Dongle - manual]
vebus_smart_dongle_manual [2019-06-24 14:54] (current)
jpasop Moved system requirements to the top of the manual
Line 2: Line 2:
 {{:​benh7ta_79897301-690x277.png?​400|}} {{:​benh7ta_79897301-690x277.png?​400|}}
 +===== System requirements =====
 +**Multi firmware versions before 415 are not supported**
 +^ Function ​                                           ^ Minimum Multi firmware version ^ Note ^
 +| Battery voltage and temperature sense               | 419                            |      |
 +| Input current limit and on/​off/​charger only control | 415                            | Not supported when a DMC and/or VeBus BMS is installed |
 ===== Introduction ===== ===== Introduction =====
Line 50: Line 58:
   - Plug the connector block into the dongle. ​   - Plug the connector block into the dongle. ​
   - Connect the dongle to the Multi'​s Ve.Bus interface, using a standard RJ45 UTP cable   - Connect the dongle to the Multi'​s Ve.Bus interface, using a standard RJ45 UTP cable
-===== System requirements =====
-**Multi firmware versions before 415 are not supported**
-^ Function ​                                           ^ Minimum Multi firmware version ^ Note ^
-| Battery voltage and temperature sense               | 419                            |      |
-| Input current limit and on/​off/​charger only control | 415                            | Not supported when a DMC and/or VeBus BMS is installed |
 ===== LED Status codes ===== ===== LED Status codes =====
vebus_smart_dongle_manual.txt · Last modified: 2019-06-24 14:54 by jpasop
