ve.direct:ve.direct_to_bluetooth_smart_dongle [2016-05-23 16:30]
thiemovanengelen [Troubleshooting]
ve.direct:ve.direct_to_bluetooth_smart_dongle [2019-01-22 10:16] (current)
 ====== Manual - VE.Direct to Bluetooth Smart dongle ====== ====== Manual - VE.Direct to Bluetooth Smart dongle ======
-**Note: this product was previously called the VE.Direct to Bluetooth LE dongle**. There are no differences, only the name has changed from LE to Smart.
 Product page on our main website:\\ Product page on our main website:\\
Line 7: Line 5:
 {{:ve.direct:ve._direct_bluetooth_smart_dongle.jpg?200|}} {{:ve.direct:ve._direct_bluetooth_smart_dongle.jpg?200|}}
-{{:victronconnect:vc_iphone_discovery.png?direct&150|VictronConnect - Discovery}} +{{:ve.direct:vc4_iphone_discovery_vedirect.png?direct&150|VictronConnect - Discovery}}
-{{:victronconnect:vc_iphone_bluesolar_live.png?direct&150|VictronConnect - BlueSolar Live}} +{{:victronconnect:vc4_iphone_bluesolar_live.png?direct&150|VictronConnect - BlueSolar Live}}
-{{:victronconnect:vc_iphone_bluesolar_streetlightsettings.png?direct&150|VictronConnect - BlueSolar Settings}}+{{:victronconnect:vc4_iphone_bluesolar_streetlightsettings.png?direct&150|VictronConnect - BlueSolar Settings}}
-With the VE.Direct to Bluetooth Smart dongle you can get live status info, see historical values as well as configure Victron products. The dongle works together with the [[https://www.victronenergy.com/support-and-downloads/software#victronconnect-app|VictronConnect App]], available for both Android and iOS devices.+With the VE.Direct to Bluetooth Smart dongle you can get live status info, see historical values as well as configure Victron products.\\  The dongle works together with the [[https://www.victronenergy.com/support-and-downloads/software#victronconnect-app|VictronConnect App]], available for both Android and iOS devices.
-==== Supported Victron products ==== +Note: this product was previously called the **VE.Direct to Bluetooth LE dongle**. There are no differences, only the name has changed from LE to Smart.
-The dongle can be connected to all Victron products that have a built-in VE.Direct port. For a full list see the [[victronconnect:start|VictronConnect App manual]].+==== Compatible Victron products ====
 +The dongle can be connected to almost all Victron products that have a built-in VE.Direct port. For a full list see the [[https://www.victronenergy.com/live/victronconnect:start#compatible_victron_products|Compatible Victron products section of the VictronConnect manual]]
 ==== Installation Notes ===== ==== Installation Notes =====
   * Connect the dongle directly to these products. The dongle cannot be connected to a Color Control GX.   * Connect the dongle directly to these products. The dongle cannot be connected to a Color Control GX.
-  * It is not possible to monitor a product using both a Color Control //and// a Bluetooth dongle at the same time.
   * It is not possible to extend the VE.Direct cable.   * It is not possible to extend the VE.Direct cable.
 +  * After connecting the first time, the Blue and Red LED will be blinking fast and alternating. It needs to be updated to the latest firmware, which will happen automatically when connecting to it with VictronConnect.
-==== Supported phones and tables ====+See [[victronconnect:start#connecting|VictronConnect manual]] for more information.
-The used device needs to have Bluetooth 4.0 (BT LE) in order to work with the dongle. For a full list of devices see the [[victronconnect:start|VictronConnect manual]].+
 +==== Supported phones, tablets and computers  ====
 +See the [[victronconnect:start|VictronConnect manual]].
Line 30: Line 33:
 The dongle works together with the VictronConnect App. Download links for iPhone, iPad as well as Android devices are available on our [[https://www.victronenergy.com/support-and-downloads/software#victronconnect-app|software page]] The dongle works together with the VictronConnect App. Download links for iPhone, iPad as well as Android devices are available on our [[https://www.victronenergy.com/support-and-downloads/software#victronconnect-app|software page]]
-==== Pairing procedure ====
-Default pin code is 000000
-After connecting, you can change the pin code by pressing the (i) button in the top right of the app.+==== LED Status codes ====
-If the dongle pin code is lostreset it to 000000 by pressing and holding the clear PIN button until the solid blue colored Bluetooth light flashes off and on momentarily.+The dongle has two LEDsBluetooth status LED (blue), and an error LED (red)
-==== LED Status codes ====+On power-up, both LEDs will be on or alternating quickly (fast blinking).
-The dongle has two LEDs, a Bluetooth status LED (blue), and an error LED (red)On power-up, both LEDs will be on. When both LEDs stay on, something is wrong with the communication on VE.Direct.+When both LEDs are onthe dongle contains valid firmware and will act as VE.Direct gateway. When both LEDs stay on, something is wrong with the communication on VE.Direct.
-^ BLE State      ^ Blue LED       ^ Red LED       ^ Remark +When the LEDs are alternating quickly, the dongle is in firmware update mode and it will show up as dongle in VictronConnect. After connecting, a firmware update can be performed. When the dongle already contains valid firmware, it will fall back to normal operation after 30 seconds.
-| Disabled       | On             | On            | VE.Direct communication problem. \\ The dongle will not advertise itself so it will not be visible in VictronConnect. +
-| Not connected  | Slow blinking  | Off                   | +
-| Connected      | On             | Off                   | +
-| Clearing pin   | Double flash   | Double flash  |         |+
-During firmware updates there are some additional LED status codes when the device is in bootloader.
-^ BLE State      ^ Blue LED       ^ Red LED          ^ Remark       +^ Blue LED       ^ Red LED          ^ Dongle state      ^ Connection State ^ Remark
-| Not connected  | Fast blinking  | Fast blinking    | Red and Blue LED Alternating +| On             | On               | VE.Direct gateway | Disabled         | VE.Direct communication problem. \\ The dongle will not advertise itself so \\ it will not be visible in VictronConnect. |
-| Connected      | On             | Slow blinking    |              | +| Slow blinking  | Off              | VE.Direct gateway | Not connected            |
-Uploading      | On             Faster blinking               | +| On             | Off              | VE.Direct gateway | Connected        |         |
-| Programming    Fast blinking  | Off              |              |+| Double flash   | Double flash     | VE.Direct gateway | Not connected    | Confirm pin has been cleared        |
 +| Fast blinking  | Fast blinking    | Firmware update   | Not connected    | Red and Blue LED Alternating
 +| On             | Slow blinking    | Firmware update   Connected                |
 +| On             Fast blinking    Firmware update   | Programming              |
 ==== Troubleshooting ==== ==== Troubleshooting ====
 **I don't see my product in the discovery screen** **I don't see my product in the discovery screen**
   * Only one phone or tablet can be connected to a dongle at the same time. Make sure no other devices are connected to the dongle, and try again.   * Only one phone or tablet can be connected to a dongle at the same time. Make sure no other devices are connected to the dongle, and try again.
   * The dongle does not support all Victron products. Check if your Victron product is listed in the section above.   * The dongle does not support all Victron products. Check if your Victron product is listed in the section above.
-  * The dongle is powered via the VE.Direct cable connection. Make sure the dongle is connected to a supported device and the LEDs blink when connecting the cable or power is turned on.+  * The dongle is powered via the VE.Direct cable connection. Make sure the dongle is connected to a supported device, check that the devices is powered, and the LEDs blink when connecting the cable or power is turned on.
 **I cannot connect to the dongle** **I cannot connect to the dongle**
   * Make sure you are close enough to the dongle. In open space, a distance of up to approximately 20 meters should work.   * Make sure you are close enough to the dongle. In open space, a distance of up to approximately 20 meters should work.
   * Connection issues might be caused by an incorrect Bluetooth pairing. Try re-pairing by first removing the pairing from the phone: go to your phone's Settings, then click Bluetooth. Click the (i)-icon next to any "VE.Direct LE" device and click "Forget This Device". Then, open the VictronConnect app again and pull down the Discovery screen to rediscover products. Set the dongle in pairing mode by clicking the button on the dongle, then click the Victron product in the app's Discovery screen. Confirm the pairing and you should now be connected to the dongle.   * Connection issues might be caused by an incorrect Bluetooth pairing. Try re-pairing by first removing the pairing from the phone: go to your phone's Settings, then click Bluetooth. Click the (i)-icon next to any "VE.Direct LE" device and click "Forget This Device". Then, open the VictronConnect app again and pull down the Discovery screen to rediscover products. Set the dongle in pairing mode by clicking the button on the dongle, then click the Victron product in the app's Discovery screen. Confirm the pairing and you should now be connected to the dongle.
 **My dongle has a VE.Direct communication problem. What should I do?** **My dongle has a VE.Direct communication problem. What should I do?**
   * Assure that the product it is connected to is working properly.   * Assure that the product it is connected to is working properly.
   * Try to disconnect the dongle and reconnect to the same product.   * Try to disconnect the dongle and reconnect to the same product.
   * Try to connect the dongle to a different product when available.   * Try to connect the dongle to a different product when available.
-  * Check if VictronConnect can see the device when using a VE.Direct cable connected to a PC or android phone+  * Check if VictronConnect can see the device when using a VE.Direct USB cable connected to a PC or android phone
-===== Update dongle firmware =====+See the [[https://www.victronenergy.com/live/victronconnect:start#troubleshooting|Trouble shooting section in the VictronConnect manual]] for more information.
-After connecting with new VictronConnect version for the first time, it might be that the firmware of the dongle needs to be updated. Be warned that this dongle firmware update can be a bit of a hassle: all steps need to be patiently and accurately followed.+**I have Motorola Moto G 2014 (aka Moto G2) and cannot connect to the dongle**
-The update might need multiple steps: repeat the process untill the dongle entry disappears from the list and the product connected to the dongle is listed instead.+That Motorola model has a known issue with VE.Direct Bluetooth Smart dongle, serial number HQ1606 and earlier. If you have such serial number and that phone, contact Victron Repairs for a replacement.
-There are small differences between the Android and iOS update process.+All other Android phones, tables and other products which we have tested do not have problem with that dongle.
 +===== Update dongle firmware =====
-**If you get stuck in any point of the update process just close and open the app again. That should reset the update process to the last completed step.**+After connecting with a new VictronConnect version for the first time, it might be that the firmware of the dongle needs to be updated, follow the instructions displayed on VictronConnect to complete the process.
-==== Android ====+===== Current draw =====
-Follow these instructions {{:ve.direct:updating_ve.direct_smart_dongle_with_android_device.pdf|in this pdf}}.+When not connected via Bluetooth with a phone/tablet/laptop< 1mA
-==== iOS =====+When connected by a phone: < 2.5mA
-  - The dongle has to be paired before starting the update. +===== Product dimensions =====
-  - After the first update step is completed go to the iPhone/iPad bluetooth settings and remove the dongle from the paired devices list. Then go back to the VictronConnect app and continue with the second step.+
-Update sequence:\\ +The housing used for this product is the Hammond Manufacturing 1551GFLExact dimensions can be found [[http://www.hammondmfg.com/pdf/1551GFL.pdf|here]]
-{{:victronconnect:vc_donglefwupdate_ios_discovery.png?300}} +
-{{:victronconnect:vc_donglefwupdate_ios_firststep.png?300|}} +
-{{:victronconnect:vc_donglefwupdate_ios_firststepupdating.png?300|}}+
-At this stage go to the iPhone/iPad bluetooth settings and remove the dongle from the paired devices list:\\ +The length of the VE.Direct cable is 1.5m
-{{:victronconnect:vc_donglefwupdate_ios_removepairing.gif}}+
-Now open VictronConnect again, and continue the update:\\
-{{:victronconnect:vc_donglefwupdate_ios_secondstep.png?300|}}
-{{:victronconnect:vc_donglefwupdate_ios_scondstepupdating.png?300|}}
-===== DISQUS Comments =====
 +===== DISQUS =====
 ~~DISQUS~~ ~~DISQUS~~
ve.direct/ve.direct_to_bluetooth_smart_dongle.1464013814.txt.gz · Last modified: 2016-05-23 16:30 by thiemovanengelen
