ve.direct:ve.direct_to_bluetooth_smart_dongle [2018-01-06 03:47] – [Manual - VE.Direct to Bluetooth Smart dongle] jperez | ve.direct:ve.direct_to_bluetooth_smart_dongle [2021-01-19 10:17] – mkuiken | ||
====== Manual - VE.Direct to Bluetooth Smart dongle ====== | ====== Manual - VE.Direct to Bluetooth Smart dongle ====== | ||
- | **Note: this product was previously called the VE.Direct to Bluetooth LE dongle**. There are no differences, | ||
Product page on our main website:\\ | Product page on our main website:\\ | ||
Line 11: | Line 9: | ||
+ | Note: this product was previously called the **VE.Direct to Bluetooth LE dongle**. There are no differences, | ||
==== Compatible Victron products ==== | ==== Compatible Victron products ==== | ||
- | The dongle can be connected to almost all Victron products that have a built-in VE.Direct port. For a full list see the [[victronconnect: | + | The dongle can be connected to almost all Victron products that have a built-in VE.Direct port. For a full list see the [[https:// |
Line 47: | Line 46: | ||
^ Blue LED ^ Red LED ^ Dongle state ^ Connection State ^ Remark | ^ Blue LED ^ Red LED ^ Dongle state ^ Connection State ^ Remark | ||
- | | On | On | VE.Direct gateway | Disabled | + | | Slow blinking |
+ | | On | On | VE.Direct gateway | Connected | ||
| Slow blinking | | Slow blinking | ||
| On | Off | VE.Direct gateway | Connected | | On | Off | VE.Direct gateway | Connected | ||
- | | Double flash | Double flash | VE.Direct gateway | Clearing pin | | + | | Double flash | Double flash | VE.Direct gateway | Not connected |
- | | Fast blinking | + | |
Line 73: | Line 72: | ||
* Try to disconnect the dongle and reconnect to the same product. | * Try to disconnect the dongle and reconnect to the same product. | ||
* Try to connect the dongle to a different product when available. | * Try to connect the dongle to a different product when available. | ||
- | * Check if VictronConnect can see the device when using a VE.Direct cable connected to a PC or android phone | + | * Check if VictronConnect can see the device when using a VE.Direct |
See the [[https:// | See the [[https:// | ||
Line 98: | Line 97: | ||
The length of the VE.Direct cable is 1.5m | The length of the VE.Direct cable is 1.5m | ||
