ve.direct:ve.direct_to_bluetooth_smart_dongle [2017-09-13 22:01] – [Troubleshooting] mvader | ve.direct:ve.direct_to_bluetooth_smart_dongle [2018-11-30 12:19] – [LED Status codes] mkuiken | ||
====== Manual - VE.Direct to Bluetooth Smart dongle ====== | ====== Manual - VE.Direct to Bluetooth Smart dongle ====== | ||
- | **Note: this product was previously called the VE.Direct to Bluetooth LE dongle**. There are no differences, | ||
Product page on our main website:\\ | Product page on our main website:\\ | ||
Line 7: | Line 5: | ||
- | {{:victronconnect:vc_iphone_discovery.png? | + | {{:ve.direct:vc4_iphone_discovery_vedirect.png? |
- | ==== Supported | + | Note: this product was previously called the **VE.Direct to Bluetooth LE dongle**. There are no differences, |
- | The dongle can be connected to all Victron products that have a built-in VE.Direct port. For a full list see the [[victronconnect: | + | ==== Compatible |
+ | The dongle can be connected to almost all Victron products that have a built-in VE.Direct port. For a full list see the [[https:// | ||
* Connect the dongle directly to these products. The dongle cannot be connected to a Color Control GX. | * Connect the dongle directly to these products. The dongle cannot be connected to a Color Control GX. | ||
- | * It is not possible to monitor a product using both a Color Control //and// a Bluetooth dongle at the same time. | ||
* It is not possible to extend the VE.Direct cable. | * It is not possible to extend the VE.Direct cable. | ||
* After connecting the first time, the Blue and Red LED will be blinking fast and alternating. It needs to be updated to the latest firmware, which will happen automatically when connecting to it with VictronConnect. | * After connecting the first time, the Blue and Red LED will be blinking fast and alternating. It needs to be updated to the latest firmware, which will happen automatically when connecting to it with VictronConnect. | ||
- | See [[victronconnect: | + | See [[victronconnect: |
Line 50: | Line 49: | ||
| Slow blinking | | Slow blinking | ||
| On | Off | VE.Direct gateway | Connected | | On | Off | VE.Direct gateway | Connected | ||
- | | Double flash | Double flash | VE.Direct gateway | Clearing pin | | + | | Double flash | Double flash | VE.Direct gateway | Not connected |
- | | Fast blinking | + | |
Line 73: | Line 71: | ||
* Try to disconnect the dongle and reconnect to the same product. | * Try to disconnect the dongle and reconnect to the same product. | ||
* Try to connect the dongle to a different product when available. | * Try to connect the dongle to a different product when available. | ||
- | * Check if VictronConnect can see the device when using a VE.Direct cable connected to a PC or android phone | + | * Check if VictronConnect can see the device when using a VE.Direct |
See the [[https:// | See the [[https:// | ||
Line 91: | Line 89: | ||
When connected by a phone: < 2.5mA | When connected by a phone: < 2.5mA | ||
+ | ===== Product dimensions ===== | ||
+ | The housing used for this product is the Hammond Manufacturing 1551GFL. Exact dimensions can be found [[http:// | ||
+ | The length of the VE.Direct cable is 1.5m | ||
===== DISQUS Comments ===== | ===== DISQUS Comments ===== | ||
~~DISQUS~~ | ~~DISQUS~~ |
