ve.direct:ve.direct_to_bluetooth_smart_dongle [2016-06-03 12:41] – [LED Status codes] thiemovanengelen | ve.direct:ve.direct_to_bluetooth_smart_dongle [2021-01-19 10:17] – mkuiken | ||
====== Manual - VE.Direct to Bluetooth Smart dongle ====== | ====== Manual - VE.Direct to Bluetooth Smart dongle ====== | ||
- | **Note: this product was previously called the VE.Direct to Bluetooth LE dongle**. There are no differences, | ||
Product page on our main website:\\ | Product page on our main website:\\ | ||
Line 7: | Line 5: | ||
- | {{:victronconnect:vc_iphone_discovery.png? | + | {{:ve.direct:vc4_iphone_discovery_vedirect.png? |
- | ==== Supported | + | Note: this product was previously called the **VE.Direct to Bluetooth LE dongle**. There are no differences, |
- | The dongle can be connected to all Victron products that have a built-in VE.Direct port. For a full list see the [[victronconnect: | + | ==== Compatible |
+ | The dongle can be connected to almost all Victron products that have a built-in VE.Direct port. For a full list see the [[https:// | ||
* Connect the dongle directly to these products. The dongle cannot be connected to a Color Control GX. | * Connect the dongle directly to these products. The dongle cannot be connected to a Color Control GX. | ||
- | * It is not possible to monitor a product using both a Color Control //and// a Bluetooth dongle at the same time. | ||
* It is not possible to extend the VE.Direct cable. | * It is not possible to extend the VE.Direct cable. | ||
- | * After connecting the first time, the Blue and Red LED will be blinking fast and alternating. It needs to be updated to the latest firmware, which will happen automatically when connecting to it with [[victronconnect: | + | * After connecting the first time, the Blue and Red LED will be blinking fast and alternating. It needs to be updated to the latest firmware, which will happen automatically when connecting to it with VictronConnect. |
+ | See [[victronconnect: | ||
- | ==== Supported phones and tables | + | ==== Supported phones, tablets |
- | The used device needs to have Bluetooth 4.0 (BT LE) in order to work with the dongle. For a full list of devices see the [[victronconnect: | + | See the [[victronconnect: |
Line 31: | Line 33: | ||
The dongle works together with the VictronConnect App. Download links for iPhone, iPad as well as Android devices are available on our [[https:// | The dongle works together with the VictronConnect App. Download links for iPhone, iPad as well as Android devices are available on our [[https:// | ||
- | ==== Pairing procedure ==== | ||
- | Default pin code is 000000 | ||
- | After connecting, you can change the pin code by pressing the (i) button in the top right of the app. | ||
- | If the dongle pin code is lost, reset it to 000000 by pressing and holding the clear PIN button until the solid blue colored Bluetooth light flashes off and on momentarily. | ||
==== LED Status codes ==== | ==== LED Status codes ==== | ||
Line 50: | Line 46: | ||
^ Blue LED ^ Red LED ^ Dongle state ^ Connection State ^ Remark | ^ Blue LED ^ Red LED ^ Dongle state ^ Connection State ^ Remark | ||
- | | On | On | VE.Direct gateway | Disabled | + | | Slow blinking |
+ | | On | On | VE.Direct gateway | Connected | ||
| Slow blinking | | Slow blinking | ||
| On | Off | VE.Direct gateway | Connected | | On | Off | VE.Direct gateway | Connected | ||
- | | Double flash | Double flash | VE.Direct gateway | Clearing pin | | + | | Double flash | Double flash | VE.Direct gateway | Not connected |
- | | Fast blinking | + | |
**I don't see my product in the discovery screen** | **I don't see my product in the discovery screen** | ||
* Only one phone or tablet can be connected to a dongle at the same time. Make sure no other devices are connected to the dongle, and try again. | * Only one phone or tablet can be connected to a dongle at the same time. Make sure no other devices are connected to the dongle, and try again. | ||
* The dongle does not support all Victron products. Check if your Victron product is listed in the section above. | * The dongle does not support all Victron products. Check if your Victron product is listed in the section above. | ||
- | * The dongle is powered via the VE.Direct cable connection. Make sure the dongle is connected to a supported device and the LEDs blink when connecting the cable or power is turned on. | + | * The dongle is powered via the VE.Direct cable connection. Make sure the dongle is connected to a supported device, check that the devices is powered, |
**I cannot connect to the dongle** | **I cannot connect to the dongle** | ||
* Make sure you are close enough to the dongle. In open space, a distance of up to approximately 20 meters should work. | * Make sure you are close enough to the dongle. In open space, a distance of up to approximately 20 meters should work. | ||
* Connection issues might be caused by an incorrect Bluetooth pairing. Try re-pairing by first removing the pairing from the phone: go to your phone' | * Connection issues might be caused by an incorrect Bluetooth pairing. Try re-pairing by first removing the pairing from the phone: go to your phone' | ||
**My dongle has a VE.Direct communication problem. What should I do?** | **My dongle has a VE.Direct communication problem. What should I do?** | ||
* Assure that the product it is connected to is working properly. | * Assure that the product it is connected to is working properly. | ||
* Try to disconnect the dongle and reconnect to the same product. | * Try to disconnect the dongle and reconnect to the same product. | ||
* Try to connect the dongle to a different product when available. | * Try to connect the dongle to a different product when available. | ||
- | * Check if VictronConnect can see the device when using a VE.Direct cable connected to a PC or android phone | + | * Check if VictronConnect can see the device when using a VE.Direct |
- | ===== Update dongle firmware ===== | + | See the [[https:// |
- | After connecting with a new VictronConnect version for the first time, it might be that the firmware of the dongle | + | **I have a Motorola Moto G 2014 (aka Moto G2) and cannot connect to the dongle** |
- | The update might need multiple steps: repeat the process untill the dongle | + | That Motorola model has a known issue with VE.Direct Bluetooth Smart dongle, serial number HQ1606 |
- | There are small differences between the Android and iOS update process. | + | All other Android |
+ | ===== Update dongle firmware ===== | ||
- | **If you get stuck in any point of the update process just close and open the app again. That should reset the update process | + | After connecting with a new VictronConnect version for the first time, it might be that the firmware of the dongle needs to be updated, follow |
- | ==== Android | + | ===== Current draw ===== |
- | Follow these instructions {{:ve.direct: | + | When not connected via Bluetooth with a phone/ |
- | ==== iOS ===== | + | When connected by a phone: < 2.5mA |
- | - The dongle has to be paired before starting the update. | + | ===== Product dimensions ===== |
- | - After the first update step is completed go to the iPhone/iPad bluetooth settings and remove the dongle from the paired devices list. Then go back to the VictronConnect app and continue with the second step. | + | |
- | Update sequence: | + | The housing used for this product is the Hammond Manufacturing 1551GFL. Exact dimensions can be found [[http://www.hammondmfg.com/ |
- | {{:victronconnect: | + | |
- | At this stage go to the iPhone/iPad bluetooth settings and remove the dongle from the paired devices list:\\ | + | The length of the VE.Direct cable is 1.5m |
- | Now open VictronConnect again, and continue the update:\\ | ||
