ve.direct:mpptprefs
ve.direct:mpptprefs [2016-04-21 22:14] – d.t.schneiderlein | ve.direct:mpptprefs [2019-01-22 10:16] (current) – external edit 127.0.0.1 | ||
====== Changing settings in the BlueSolar MPPT Charge Controllers ====== | ====== Changing settings in the BlueSolar MPPT Charge Controllers ====== | ||
- | ===== Applicable products | + | |
+ | ===== THIS PAGE IS DEPRECATED: Use VictronConnect instead of mpptprefs | ||
+ | We recommend to use [[victronconnect: | ||
+ | More information: | ||
+ | Products: | ||
* BlueSolar Charge controller MPPT 70/15 (replaced with the 75/15) | * BlueSolar Charge controller MPPT 70/15 (replaced with the 75/15) | ||
Line 18: | Line 29: | ||
===== Instructions ===== | ===== Instructions ===== | ||
- | * Download mpptprefs.exe here: [[https:// | ||
* In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https:// | * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https:// | ||
Line 120: | Line 130: | ||
Change the load switch on/off behavior. By default the battery life algorithm will be used (option 1). Normally a jumper can be used to select between two fixed switch on/off set-points. However if you require communication with the charger (e.g. when connecting a Color Control) you can use options 2 or 3 to preset a conventional algorithm. Options 5 and 6 can be used to create custom algorithms, with programmable switch on and switch off levels (see options ' | Change the load switch on/off behavior. By default the battery life algorithm will be used (option 1). Normally a jumper can be used to select between two fixed switch on/off set-points. However if you require communication with the charger (e.g. when connecting a Color Control) you can use options 2 or 3 to preset a conventional algorithm. Options 5 and 6 can be used to create custom algorithms, with programmable switch on and switch off levels (see options ' | ||
+ | Keep in mind that modes 0 (always off) and 4 (always on) will respond immediately, | ||
Line 319: | Line 331: | ||
- | ~~DISQUS~~ | ||
- | Is there any way to switch off MPPT? I would like to use this device as a wind controller and MPPT is not helpfull for that. | + | ===== DISQUS ===== |
+ | ~~DISQUS~~ | ||
ve.direct/mpptprefs.1461269661.txt.gz · Last modified: 2016-04-21 22:14 by d.t.schneiderlein
