ve.direct:mpptprefs
ve.direct:mpptprefs [2017-09-05 20:48] – [THIS PAGE IS DEPRECATED: Use VictronConnect instead of mpptprefs] mvader | ve.direct:mpptprefs [2019-01-21 11:13] – [Batch mode] ictbeheer | ||
Line 29: | Line 29: | ||
===== Instructions ===== | ===== Instructions ===== | ||
- | * Download mpptprefs.exe here: [[https:// | ||
* In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https:// | * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https:// | ||
Line 332: | Line 331: | ||
- | ~~DISQUS~~ | ||
