ve.direct:mpptprefs
ve.direct:mpptprefs [2017-08-09 02:10] – [DEPRECATED: Use VictronConnect instead of mpptprefs] guystewart | ve.direct:mpptprefs [2019-01-22 10:16] (current) – external edit 127.0.0.1 | ||
Line 4: | Line 4: | ||
===== THIS PAGE IS DEPRECATED: Use VictronConnect instead of mpptprefs ===== | ===== THIS PAGE IS DEPRECATED: Use VictronConnect instead of mpptprefs ===== | ||
- | We recommend to use [[victronconnect: | + | We recommend to use [[victronconnect: |
+ | More information: [[victronconnect: | ||
Line 27: | Line 29: | ||
===== Instructions ===== | ===== Instructions ===== | ||
- | * Download mpptprefs.exe here: [[https:// | ||
* In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https:// | * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https:// | ||
Line 330: | Line 331: | ||
