ve.direct:mpptprefs
ve.direct:mpptprefs [2015-04-22 16:37] rvanzundertve.direct:mpptprefs [2019-01-22 10:16] (current) – external edit 127.0.0.1
 ====== Changing settings in the BlueSolar MPPT Charge Controllers ====== ====== Changing settings in the BlueSolar MPPT Charge Controllers ======
-===== Applicable products =====+
 +===== THIS PAGE IS DEPRECATED: Use VictronConnect instead of mpptprefs =====
 +We recommend to use [[victronconnect:start|VictronConnect]] instead of mpptprefs. Much simpler and faster to use. Also it includes automatic firmware updates.
 +More information: [[victronconnect:mppt-solarchargers|]]
 +===== Original text =====
 +Products:
   * BlueSolar Charge controller MPPT 70/15 (replaced with the 75/15)   * BlueSolar Charge controller MPPT 70/15 (replaced with the 75/15)
Line 11: Line 22:
   * BlueSolar Charge controller MPPT 100/50   * BlueSolar Charge controller MPPT 100/50
   * BlueSolar Charge controller MPPT 150/35   * BlueSolar Charge controller MPPT 150/35
-  +  * BlueSolar Charge controller MPPT 150/45 (Tr/MC-4)
 +  * BlueSolar Charge controller MPPT 150/60 (Tr/MC-4)
 +  * BlueSolar Charge controller MPPT 150/70 (Tr/MC-4)
 +  * BlueSolar Charge controller MPPT 150/85 (Tr/MC-4)
 +  * BlueSolar Charge controller MPPT 150/100 (Tr/MC-4)
 ===== Instructions ===== ===== Instructions =====
-  * Download mpptprefs.exe here: [[http://www.victronenergy.com/support-and-downloads/software#mpptprefs|http://www.victronenergy.com/support-and-downloads/software#mpptprefs]]+  * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https://www.victronenergy.com/support-and-downloads/software#ve-power-setup|VE Power Setup section on our Software page]].
 ===== VE.Direct connection ===== ===== VE.Direct connection =====
Line 30: Line 45:
   * Start the mpptprefs.exe tool by double-clicking on it. The tool will try to locate the MPPT charger by scanning the available ports and downloading the settings once it finds a compatible charger. First you will see an overview of charger model, firmware version and the actual settings, similar to that shown below (MPPT 100/15 model used in this instance):   * Start the mpptprefs.exe tool by double-clicking on it. The tool will try to locate the MPPT charger by scanning the available ports and downloading the settings once it finds a compatible charger. First you will see an overview of charger model, firmware version and the actual settings, similar to that shown below (MPPT 100/15 model used in this instance):
-{{  :ve.direct:5a7565fd7468544e080561ceb5b713a7.png  }}+{{  :ve.direct:mpptprefs_main.png  }}
   * When the settings are to your liking, make sure to press x and enter to save them to the connected charger.   * When the settings are to your liking, make sure to press x and enter to save them to the connected charger.
Line 74: Line 89:
   * 250 = every 250 days   * 250 = every 250 days
 +When Automatic equalization is active, the absorption charge will be followed by a voltage limited constant current period. The current is limited to 8% of the bulk current for all VRLA (Gel or AGM) batteries and some flooded batteries, and to 25% of the bulk current for all tubular plate batteries. The bulk current is the rated charger current unless a lower maximum current setting has been chosen (option 'c'). In case of all VRLA batteries and some flooded batteries (algorithm number 0, 1, 2 or 3) automatic equalization ends when the voltage limit maxV has been reached, or after t = (absorption time)/8, whichever comes first. For all tubular plate batteries automatic equalization ends after t = (absorption time)/2.
 Available from firmware 1.16 and higher. Available from firmware 1.16 and higher.
 +**k**  - Modify temperature compensation
 +Set-up temperature compensation. Allowed range -21mV/K .. 21mV/K, use value 0 to disable the temperature compensation (e.g. for Lithium batteries).
 +Please note that the temperature compensation is not dynamic during operation. The charger uses its internal temperature for the battery temperature compensation when the charger has been idle for at least one hour, i.e. when the charger is not actively charging a battery or supplying a load.
 +**m**  - Modify absorption time limit
 +Set-up the absorption time limit. Enter the time value in the notation hh:mm, where hh=hours (0..12), mm=minutes (00..59).
 +The maximum duration of the absorption period is determined by the battery voltage measured just before the solar charger starts up in the morning:
 +^Battery voltage Vb (@start-up) ^ Multiplier ^ Maximum absorption times ^
 +|          Vb < 11.9V              x 1           06:00 hours        |
 +|      11.9V < Vb < 12.2V         x 2/3    |       04:00 hours        |
 +|      12.2V < Vb < 12.6V         x 1/3    |       02:00 hours        |
 +|          Vb > 12.6V             x 1/6    |       01:00 hours        |
 **t**  - Switch back to the factory defined battery table / rotary switch position \\ Modifying any of the charge parameters (a, b, f and c) automatically creates a user defined battery type. Use this option to switch back to the factory defined algorithm. **t**  - Switch back to the factory defined battery table / rotary switch position \\ Modifying any of the charge parameters (a, b, f and c) automatically creates a user defined battery type. Use this option to switch back to the factory defined algorithm.
Line 96: Line 130:
 Change the load switch on/off behavior. By default the battery life algorithm will be used (option 1). Normally a jumper can be used to select between two fixed switch on/off set-points. However if you require communication with the charger (e.g. when connecting a Color Control) you can use options 2 or 3 to preset a conventional algorithm. Options 5 and 6 can be used to create custom algorithms, with programmable switch on and switch off levels (see options 'h' and 'l'). Change the load switch on/off behavior. By default the battery life algorithm will be used (option 1). Normally a jumper can be used to select between two fixed switch on/off set-points. However if you require communication with the charger (e.g. when connecting a Color Control) you can use options 2 or 3 to preset a conventional algorithm. Options 5 and 6 can be used to create custom algorithms, with programmable switch on and switch off levels (see options 'h' and 'l').
 +Keep in mind that modes 0 (always off) and 4 (always on) will respond immediately, the other modes rely on the battery voltage and have a delay of 2 minutes before the load output will change (so the charger does not respond too quickly when for example an inrush current briefly lowers the battery below the threshold voltage).
 {{  :ve.direct:721f3e879afdb7ed21d8eec069a3a628.png  }} {{  :ve.direct:721f3e879afdb7ed21d8eec069a3a628.png  }}
Line 112: Line 148:
 **p**  - Modify lighting controller timer programs (when the lighting controller is enabled) **p**  - Modify lighting controller timer programs (when the lighting controller is enabled)
 +{{  :ve.direct:12.png  }}
 When the lighting controller is enabled (option 's'), a timer program can be created. The events 'sunset' and 'sunrise' are used as anchor points for the timer program. The lighting controller (timer) program is written to non-volatile memory, so the program will remain intact when the charger is disconnected from the battery. When the lighting controller is enabled (option 's'), a timer program can be created. The events 'sunset' and 'sunrise' are used as anchor points for the timer program. The lighting controller (timer) program is written to non-volatile memory, so the program will remain intact when the charger is disconnected from the battery.
Line 135: Line 173:
 When entering a switch on action a dim level can be entered, this results in a PWM signal on the TX port when the VE.Direct port is set into this mode (option p in the main menu). When entering a switch on action a dim level can be entered, this results in a PWM signal on the TX port when the VE.Direct port is set into this mode (option p in the main menu).
-{{  :ve.direct:12.png  }} +**m**  - Mid-point shift. The midnight point is estimated based on the solar activity, due to your geographical position and day-light saving this will deviate from the actual midnight. With the midpoint shift this can be compensated partially. Note that this setting is only relevant when your timer program uses midnight as a switching moment (like option c does). Use 0 to disable the shift (default).
-**m**  - Mid-point shift. The midnight point is estimated based on the solar activity, due to your geographical position and day-light saving this will deviate from the actual midnight. ith the midpoint shift this can be compensated partially. Note that this setting is only relevant when your timer program uses midnight as a switching moment (like option c does). Use 0 to disable the shift (default).+
 Calculation example: sunset 19:00 (=1140 min), sunrise 6:25 (=385 min) Calculation example: sunset 19:00 (=1140 min), sunrise 6:25 (=385 min)
Line 163: Line 199:
 Erase the historical data (daily logs and statistics). This data is available on the ve.direct output. A Color Control can be used to view this data. Erase the historical data (daily logs and statistics). This data is available on the ve.direct output. A Color Control can be used to view this data.
-**f**  - VE.Direct TX Port function+**p**  - VE.Direct TX Port function
 The function of the TX pin on the VE.Direct connector can be used for other functions. Available options: The function of the TX pin on the VE.Direct connector can be used for other functions. Available options:
Line 174: Line 210:
 **3**  - In combination with the lighting controller (solar timer), the light can be dimmed using an inverted PWM signal from the TX port. **3**  - In combination with the lighting controller (solar timer), the light can be dimmed using an inverted PWM signal from the TX port.
 +**4**  - Virtual load output. This enables the Streetlight functionality on the larger MPPT models. The load output can be realized via the VE.Direct connector by using cable ASS030550500. Connect the cable to a battery protect module or a solid state relay.
 Notes: the PWM output (when using options 2 and 3) operates at a fixed frequency of 160Hz and has a fixed voltage level of 5V. Notes: the PWM output (when using options 2 and 3) operates at a fixed frequency of 160Hz and has a fixed voltage level of 5V.
-{{  :ve.direct:67329505be78626e25550df988383cb2.png  }}+{{  :ve.direct:mpptprefs_tx_port.png  }}
 +**q**  - VE.Direct RX Port function
 +The function of the RX pin on the VE.Direct connector can be used for other functions. This functionality is introduced in firmware version 1.17 and applies to the 10A and 15A chargers with a load output.
 +Available options:
 +**0**  - Remote on/off. Allows remote charger on/off control (0V = switch charger off, +5V or VE.Direct communication = switch charger on), e.g. to connect to a VE.BUS BMS (using cable ASS030550300).
 +**1**  - Load output configuration (default behavior).
 +**2**  - Load output on/off. Allows remote control of the load output (0V = switch load on, +5V or VE.Direct communication = switch load off).
 +{{  :ve.direct:mpptprefs_rx_port.png  }}
 ===== Batch mode ===== ===== Batch mode =====
Line 192: Line 243:
 The output should look like the screenshot below. The output should look like the screenshot below.
-{{  :ve.direct:3c2ed0ef580b72ca1d9a498852d3d7fd.png  }}+{{  :ve.direct:mpptprefs_cmd_line_abs.png  }}
   * In order to restore factory defined charge algorithm behaviour, issue the following command:   * In order to restore factory defined charge algorithm behaviour, issue the following command:
Line 211: Line 262:
 <code> <code>
-VE.Direct mpptprefs 1.12+VE.Direct mpptprefs 1.15
 Allowed options: Allowed options:
   -d [ --dump ]            dump communication to output   -d [ --dump ]            dump communication to output
Line 224: Line 275:
   -i [ --eqv ] arg         set equalisation voltage   -i [ --eqv ] arg         set equalisation voltage
   -j [ --autoeq ] arg      set auto equalise mode   -j [ --autoeq ] arg      set auto equalise mode
 +  -k [ --tempcomp ] arg    set temperature compensation
 +  -m [ --abslim ] arg      set absorption time limit
   -t [ --table ]           use factory defined battery table   -t [ --table ]           use factory defined battery table
   -r [ --reset ]           reset all settings to factory default settings   -r [ --reset ]           reset all settings to factory default settings
Line 234: Line 287:
 </code> </code>
-Note that commands -a, -f, -b, -c, -i and -j can be combined to change multiple settings at once:+Note that commands -a, -f, -b, -c, -i-j, -k and -m can be combined to change multiple settings at once:
 <code> <code>
Line 278: Line 331:
 The above sequential commands, resets the charger to factory default settings and clears the history data. The above sequential commands, resets the charger to factory default settings and clears the history data.
 +===== DISQUS =====
 ~~DISQUS~~ ~~DISQUS~~
