ve.can:updating_firmware
ve.can:updating_firmware [2017-12-05 10:47] – mvader | ve.can:updating_firmware [2018-11-13 23:10] – mvader | ||
- | this page has moved [[ccgx: | + | ====== How to update firmware - VE.Can ====== |
+ | This page explains the procedure to update firmware for products that have a VE.Can port. There are two ways: | ||
+ | - Remotely via internet - applies to systems that have a Venus-device, | ||
+ | - Locally, using a [[https:// | ||
+ | Updating the firmware of a VE.Can product is typically most convenient by using the remote option. Its then not necessary to obtain the CANUSB adapter. In case you do need, but don't have the CANUSB, contact your dealer; they' | ||
+ | ===== Method 1: Remotely via internet ===== | ||
+ | See [[vrm_portal: | ||
+ | ===== Method 2: Locally, using the CANUSB interface ===== | ||
+ | See [[ccgx: |
ve.can/updating_firmware.txt · Last modified: 2019-08-15 12:52 by guy_stewart
