ve.can:updating_firmware
ve.can:updating_firmware [2017-04-26 07:36] – [Instructions] mvader | ve.can:updating_firmware [2017-12-05 10:47] – mvader | ||
- | ====== Updating firmware of a VE.Can product ====== | + | this page has moved [[ccgx: |
- | Products which can be updated via its VE.Can port are: | + | |
- | * BlueSolar Charger 150/70 VE.Can | + | |
- | * BlueSolar Charger 150/85 VE.Can | + | |
- | * Lynx Shunt VE.Can | + | |
- | * All four Skylla-i Battery Chargers | + | |
- | * Skylla-i Remote Control Panel | + | |
- | * All our different VE.Can to VE.Bus/ | + | |
- | * Ion Control | + | |
- | Products with a VE.Can port that need to be updated differently are: | + | |
- | * Lynx Ion (update via USB port instead) | + | |
- | * Lynx Ion + Shunt (update via USB port instead) | + | |
- | * VE.Can tank sender adapter (no updates available) | + | |
- | * Color Control GX (update via internet or with an [[ccgx: | + | |
- | ===== Instructions ===== | + | |
- | There are two ways to update the firmware via the VE.Can port: | + | |
- | - Product connected locally to the laptop. Requires the CANUSB adapter, ASS030532000. | + | |
- | - Product connect remotely, to a Color Control GX: [[ccgx: | + | |
- | That last option is often the easiest way, as there is no other use to the CANUSB and it is quite expensive. | + | |
- | Steps: | + | |
- | - Download VE Power Setup from our download | + | |
- | - Obtain the necessary firmware file on [[https:// | + | |
- | - Follow instructions in VE Power Setup. | + | |
- | - When having issues, make sure to check the information behind the '' | + |
ve.can/updating_firmware.txt · Last modified: 2019-08-15 12:52 by guy_stewart
