Introduction
This page is created to inform you on the details of NMEA 2000 PGNs that are transmitted by Victron CAN enabled products.
Victron Energy proprietary message format: VREGs
Not all values reported by the Victron products can be sent with standard NMEA 2000 PGN’s. These values are available by the proprietary message 61184 (0xEF00) to the broadcast address 61439 (0xEFFF).
See the document “VE.Can registers - public.docx” for detailed information and examples, available on request via mvader@victronenergy.com.
Switch Bank Control - PGN 127502 (0x1F20E) (deprecated)
This message is no longer transmitted and has been replaced by PGN 127501.
This applies to products with versions as specified in the table below or newer.
| Product | Version |
| BlueSolar MPPT 150/70 & 150/85 | v2.00 |
| Lynx Shunt VE.Can | v1.00 |
| Skylla-i (all models) | v1.08 |
| VE.Direct to VE.Can\NMEA 2000 interface | v1.06 |
| VE.Bus to VE.Can\NMEA 2000 interface | v0.12 |
Binary Status Report - PGN 127501 (0x1F20D)
This PGN is sent out by multiple products, however the details differ per product.
BlueSolar Charger 150/70 & 150/85
| Signal | Meaning |
| Bank Instance | Instance of the message, default value 0 |
| Status 1 - Relay | “On” - The relay on the charger is active, the contact is closed |
| Status 2 - Alarm | “On” - There is an alarm condition |
| Status 3 - Low voltage | “On” - Battery voltage is too low |
| Status 4 - High voltage | “On” - Battery voltage is too high |
| Status 5 - Solar activity* | “On” - Solar panel irradiated (can be used for day/night detection) |
| Status 6 … 28 | Not used, reports as “Unavailable” |
* Since v2.01
When the Alarm status bit is set to “On”, the alarm reason can be queried using Victron propietary register 0xEDDA (Charger error code).
Lynx Shunt VE.Can
Since v1.07 the Lynx Shunt also transmits PGN 127501 for the relay trigger reason next to the PGN with the alarm reason.
The mapping of the status bits is identical to the alarm message.
The default instance of the alarm message is 0, as the default instance for the relay message is 1.
| Signal | Meaning |
| Bank Instance | Instance of the message Default value for alarm message is 0 Default value for relay message is 1 |
| Status 1 – Low voltage | “On” – Battery voltage is too low |
| Status 2 – High voltage | “On” – Battery voltage is too high |
| Status 3 – Low SOC | “On” – The Battery state of charge is too low |
| Status 4 – Low fused voltage | “On” – Fused voltage is too low |
| Status 5 – High fused voltage | “On” – Fused voltage is too high |
| Status 6 – Fuse blown | “On” – The fuse is blown |
| Status 7 – High battery temperature | “On” – Battery temperature is too high |
| Status 8 – Low battery temperature | “On” – Battery temperature is too low |
| Status 9 – High internal temperature | “On” – Internal temperature is too high |
| Status 10 … 28 | Not used, report as “Unavailable” |
The alarm and relay thresholds can be configured using Victron proprietary registers.
Skylla-i
| Signal | Meaning |
| Status 5 … 28 | Not used, reports as “Unavailable” |
Alarm and relay tresholds need to be configured on the BMV itself.
| Signal | Meaning |
| Status 3 – Low voltage* | “On” – Battery voltage is too low |
| Status 4 – High voltage* | “On” – Battery voltage is too high |
| Status 5 – Low SOC* | “On” – The Battery state of charge is too low |
| Status 6 – Low voltage 2* | “On” – Starter Battery voltage is too low |
| Status 7 – High voltage 2* | “On” – Starter Battery voltage is too high |
| Status 8 … 28 | Not used, report as “Unavailable” |
* BMV version 2.08 and higher
| Signal | Meaning |
| Status 1 … 4 | Not used, report as “Unavailable” |
| Status 5 - Low battery warning | “On” - There is a low battery voltage warning |
| Status 6 – Low battery alarm | “On” – There is a low battery voltage alarm |
| Status 7 – Temperature warning | “On” – There is a temperature warning |
| Status 8 – Temeprature alarm | “On” – There is a temperature alarm |
| Status 9 – Overload warning | “On” – There is an overload warning |
| Status 10 – Overload alarm | “On” – There is an overload alarm |
| Status 11 – Ripple warning* | “On” – There is a ripple warning |
| Status 12 – Ripple alarm* | “On” – There is a ripple alarm |
| Status 13 … 28 | Not used, report as “Unavailable” |
* Since v0.11
The LED state of the multi can be used to easily imitate the front of the multi itself. This is only for graphical purposes. Do not interpret the LED status to get the state of the device, since LED behaviour might be subject to change and combinations of LEDs have different meanings. Use the state fields themselves for these purposes. This is for GUI / user interfaces only.
| Signal | Meaning |
| Bank Instance | Instance of the message, default value 1 |
| Status 1 | Led Mains On |
| Status 2 | Led Mains Blink |
| Status 3 | Led Absorption On |
| Status 4 | Led Absorption Blink |
| Status 5 | Led Bulk On |
| Status 6 | Led Bulk Blink |
| Status 7 | Led Float On |
| Status 8 | Led Float Blink |
| Status 9 | Led Inverter On |
| Status 10 | Led Inverter Blink |
| Status 11 | Led Overload On |
| Status 12 | Led Overload Blink |
| Status 13 | Led Low Battery On |
| Status 14 | Led Low Battery Blink |
| Status 15 | Led Temperature On |
| Status 16 | Led Temperature Blink |
| Status 17 … 28 | Not used, report as “Unavailable” |
The state of an individual led can be extracted from the combined.
| Blink | On | Nibble | Meaning |
| Off | Off | 0x0000 | The LED is off |
| Off | On | 0x0001 | The LED is on |
| On | Off | 0x0100 | The LED is blinking |
| On | On | 0x0101 | The LED is blinking in opposite sense as normal blinking. When LEDs of state 0x0100 are off LED in this state are on and vice versa |
| Unavailable | Unavailable | other | Led state is not available |
| Reserved | Reserved |
Add this page to your book
Manage book (
Help
