ve.can:pgn_details
ve.can:pgn_details [2017-09-18 15:24] – [NMEA2000 PGN definitions] mvader | ve.can:pgn_details [2017-09-19 12:25] – mbosma | ||
Line 71: | Line 71: | ||
==== VE.Bus to VE.Can\NMEA 2000 interface ==== | ==== VE.Bus to VE.Can\NMEA 2000 interface ==== | ||
- | ^ Signal | + | See the manual |
- | | Bank Instance | + | |
- | | Status | + | |
- | | Status 10 – Overload alarm | “On” – There is an overload alarm | | + | |
- | | Status 11 – Ripple warning* | + | |
- | | Status 12 – Ripple alarm* | + | |
- | | Status 13 … 28 | Not used, report as “Unavailable” | | + | |
- | * Since v0.11 | + | |
- | The LED state of the multi can be used to easily imitate the front of the multi itself. This is only for graphical purposes. Do not interpret the LED status | + | |
- | ^ Signal | + | |
- | | Status 1 | Led Mains On | | + | |
- | | Status 2 | Led Mains Blink | | + | |
- | | Status 3 | Led Absorption On | | + | |
- | | Status 4 | Led Absorption Blink | | + | |
- | | Status 5 | Led Bulk On | | + | |
- | | Status 6 | Led Bulk Blink | | + | |
- | | Status 7 | Led Float On | | + | |
- | | Status 8 | Led Float Blink | | + | |
- | | Status 9 | Led Inverter On | | + | |
- | | Status 10 | Led Inverter Blink | | + | |
- | | Status 11 | Led Overload | + | |
- | | Status 12 | Led Overload Blink | | + | |
- | | Status 13 | Led Low Battery On | | + | |
- | | Status 14 | Led Low Battery Blink | | + | |
- | | Status 15 | Led Temperature On | | + | |
- | | Status 16 | Led Temperature Blink | | + | |
- | | Status 17 … 28 | Not used, report as “Unavailable” | | + | |
- | The state of an individual led can be extracted from the combined. | + | |
- | ^ Blink ^ On ^ Nibble ^ Meaning ^ | + | |
- | | Off | Off | 0x0000 | The LED is off | | + | |
- | | Off | On | 0x0001 | The LED is on | | + | |
- | | On | Off | 0x0100 | The LED is blinking | | + | |
- | | On | On | 0x0101 | The LED is blinking in opposite sense as normal blinking.\\ When LEDs of state 0x0100 are off LED in this state are on and vice versa | | + | |
- | | Unavailable | Unavailable | other | Led state is not available | | + | |
- | | Reserved | + | |
ve.can/pgn_details.txt · Last modified: 2019-01-22 10:43 by 127.0.0.1
