ve.can:pgn_details
ve.can:pgn_details [2015-04-29 12:22] – mvader | ve.can:pgn_details [2017-09-18 15:24] – [NMEA2000 PGN definitions] mvader | ||
- | ====== NMEA2000 PGN definitions ====== | + | ====== NMEA2000 |
- | This page is created to inform you on the details of NMEA 2000 PGNs that are transmitted by Victron CAN enabled products. Note that besides NMEA2000 PGNs, we also use proprietary messages, called VREGs. VREGs are used for all parameters cannot be sent with standard NMEA 2000 PGNs. The VREG PGN number is 61184 (0xEF00), and it is sent to the broadcast address 61439 (0xEFFF). | + | |
- | See the document “VE.Can registers - public.docx” for detailed VREG information and examples. It is available on request via [[mailto::mvader@victronenergy.com|mvader@victronenergy.com]]. | + | This document is an add-on to our Datacommunication whitepaper. That whitepaper contains a list of PGNs transmitted by each product type. This document defines the bit definitions of the switch banks. |
+ | Download the main document, the Datacommunication whitepaper, from the [[https:// | ||
+ | === Proprietary messages: VREGs === | ||
+ | Note that besides the standard NMEA2000 PGNs, Victron devices also transmit proprietary messages, called VREGs. VREGs are used for all parameters cannot be sent with standard NMEA 2000 PGNs. The VREG PGN number is 61184 (0xEF00), and it is sent to the broadcast address 61439 (0xEFFF). | ||
+ | See the document “VE.Can registers - public.docx” for detailed VREG information and examples. It is available | ||
+ | === More CAN-bus and NMEA2000 related documentation === | ||
+ | * [[ve.can: | ||
===== PGN List ===== | ===== PGN List ===== | ||
Line 56: | Line 66: | ||
| Status 5 ... 28 | Not used, reports as " | | Status 5 ... 28 | Not used, reports as " | ||
When the Alarm status bit is set to “On”, the alarm reason can be queried using Victron propietary register 0xEDDA (Charger error code). | When the Alarm status bit is set to “On”, the alarm reason can be queried using Victron propietary register 0xEDDA (Charger error code). | ||
==== VE.Direct to VE.Can\NMEA 2000 interface ==== | ==== VE.Direct to VE.Can\NMEA 2000 interface ==== | ||
- | Alarm and relay tresholds need to be configured on the BMV itself. | + | See the manual |
- | ^ Signal | + | |
- | | Bank Instance | + | |
- | | Status 1 - Relay | " | + | |
- | | Status 2 - Alarm | " | + | |
- | | Status 3 – Low voltage* | + | |
- | | Status 4 – High voltage* | + | |
- | | Status 5 – Low SOC* | “On” – The Battery state of charge is too low | | + | |
- | | Status 6 – Low voltage 2* | “On” – Starter Battery voltage is too low | | + | |
- | | Status 7 – High voltage 2* | “On” – Starter Battery voltage is too high | | + | |
- | | Status 8 … 28 | Not used, report as “Unavailable” | | + | |
- | * BMV version 2.08 and higher | + | |
==== VE.Bus to VE.Can\NMEA 2000 interface ==== | ==== VE.Bus to VE.Can\NMEA 2000 interface ==== | ||
Line 114: | Line 114: | ||
| Unavailable | Unavailable | other | Led state is not available | | | Unavailable | Unavailable | other | Led state is not available | | ||
| Reserved | | Reserved | ||
ve.can/pgn_details.txt · Last modified: 2019-01-22 10:43 by 127.0.0.1
