ve.can:nmea-2000:start
ve.can:nmea-2000:start [2020-01-07 09:12] – [Q4: What PGNs does a GX Device transmit on N2K?] john_r | ve.can:nmea-2000:start [2020-04-03 00:36] – [2.1 Raymarine & EmpirBus] mvader | ||
Line 5: | Line 5: | ||
This technical document explains how to integrate a Victron system onto a Marine MFD, such as those from Garmin, Raymarine Navico and other brands. | This technical document explains how to integrate a Victron system onto a Marine MFD, such as those from Garmin, Raymarine Navico and other brands. | ||
- | There are multiple ways to integrate, so make sure to closely read the complete introductory chapter to find the best method. | + | There are multiple ways to integrate, so make sure to closely read the complete introductory chapter to find the best method |
=== Systems with a GX Device === | === Systems with a GX Device === | ||
- | For most installations and integrations, | + | For most installations and integrations, |
- | A GX Device can be connected to a Marine MFD in two ways: the simple | + | - the (simpler) |
+ | - in an the NMEA2000 network. See the [[https:// | ||
- | The other type of integration | + | Both connections can be made and used at the same time, and each has its advantages and disadvantages. |
- | Both can be used at the same time, each having its advantages and disadvantages. The MFD App is by far the simplest method. It presents an easy to use system overview without requiring any configuration. The NMEA 2000 integration on the other hand, whilst being more complex, allows more configuration on the MFD: the data will show up in the data-tree of the MFD, and most MFDs then allow the user to configure various pages and combinations of information. This is not so with the MFD App: the only possible configuration is showing and hiding battery parameters (Voltage, SOC, Current) as well as naming the batteries. | + | Note that, besides making information available on NMEA 2000, a GX Device can also read tank level data from NMEA 2000. More information in [[https:// |
- | Note that, besides making information available on NMEA 2000, a GX Device can also tank level data from NMEA 2000. More information in [[https:// | + | |
=== Direct connection - products with a VE.Can port only === | === Direct connection - products with a VE.Can port only === | ||
Line 23: | Line 22: | ||
Some of our products feature a VE.Can port; and can thus be directly connected to the NMEA 2000 network. No electronic converter necessary; only a plug conversion cable, the [[https:// | Some of our products feature a VE.Can port; and can thus be directly connected to the NMEA 2000 network. No electronic converter necessary; only a plug conversion cable, the [[https:// | ||
- | === Using our converter interfaces (deprecated) === | + | === Using our converter interfaces (DEPRECATED!) === |
Line 67: | Line 66: | ||
Line 99: | Line 98: | ||
