ve.can:nmea-2000:start
ve.can:nmea-2000:start [2016-12-11 10:22] – [1.1 Multis, MultiPlusses and Quattros] mvader | ve.can:nmea-2000:start [2019-04-03 17:39] – external edit 127.0.0.1 | ||
Line 33: | Line 33: | ||
Setting On/ | Setting On/ | ||
==== 1.2 BMV Battery Monitors ==== | ==== 1.2 BMV Battery Monitors ==== | ||
- | Use the [[https:// | + | Use the [[https:// |
Combining this with a CCGX on the same network is possible. Connect the CCGX to the N2K network as well, use our [[https:// | Combining this with a CCGX on the same network is possible. Connect the CCGX to the N2K network as well, use our [[https:// | ||
Line 110: | Line 110: | ||
* Victron BMS data | * Victron BMS data | ||
* Victron Tank sender data as well as tank sender data from other manufacturers. See chapter 1.2.7 in the [[ccgx: | * Victron Tank sender data as well as tank sender data from other manufacturers. See chapter 1.2.7 in the [[ccgx: | ||
+ | === Q5: Can integration onto Raymarine displays also be done without Empirbus NXT? === | ||
+ | No. | ||
+ | === Q6: What about Maretron and other brand tanksensors on the Ccgx? === | ||
+ | See chapter 1.2.7 in the [[ccgx: | ||
