Virtual switch - Generator start/stop
This document explains one of the ways to automatically start and stop a generator. See here for the other options.
More generator information about using a generator in combination with Victron is available here.
1. Wiring
The relay and connector block that needs to be wired to the generator control input is named the Alarm relay; in the various manuals.
1.1 MultiPlus and Quattro models of 3000VA and above
To do the wiring easily; be aware that its detachable: you can pull the block off; do the wiring; and then push it back on.
Note that there are three contacts; left to right: Normally Closed (NC) , Normally Open (NO), Common (COM).
1.2 MultiPlus-II models
1.3 MultiPlus 500VA to 1600VA models
1.4 MultiPlus Compact models
2. Configuration
2.1 enable the feature
2.2 configure the feature
Note that below are just example values; configure them to the match the type of batteries and rest of system.
The ‘stop generator when AC2 available’ feature is for Quattros; used in a backup system with generator. Wire the generator to AC-in 1; and mains to AC-in 2. With that box checked; the system will automatically stop the generator once mains is available again.
Add this page to your book
Manage book (
Help
