ve.bus:virtual-switch-generator-start-stop
ve.bus:virtual-switch-generator-start-stop [2019-01-28 12:57] – [Virtual switch - Generator start/stop] mvaderve.bus:virtual-switch-generator-start-stop [2019-09-13 14:03] (current) – [1.2 MultiPlus-II models] marmour
Line 21: Line 21:
 ==== 1.2 MultiPlus-II models ==== ==== 1.2 MultiPlus-II models ====
-The contact order for Multiplus-II is left to right: NO, NC, COM.+The contact order for MultiPlus-II is left to right: NO, NC, COM.
 {{:ve.bus:victron_multi2_relay.jpg?direct&600|}} {{:ve.bus:victron_multi2_relay.jpg?direct&600|}}
Line 35: Line 35:
 ==== 1.4  MultiPlus Compact models ==== ==== 1.4  MultiPlus Compact models ====
-{{:ve.bus:victron_multicompact_relay_2.jpg?direct&300|}}+This relay block is also removable (by pulling) for easier wiring
-{{:ve.bus:victron_multicompact_relay_close.jpg?direct&600|}}+Contact order is NO, COM, NC
 +{{:ve.bus:victron_multicompact_relay_3.jpg?direct&600|}}
 +{{:ve.bus:victron_multicompact_relay_3_close.jpg?direct&600|}}
 ===== 2. Configuration ===== ===== 2. Configuration =====
ve.bus/virtual-switch-generator-start-stop.1548676649.txt.gz · Last modified: 2019-01-28 12:57 by mvader
