ve.bus:virtual-switch-generator-start-stop
ve.bus:virtual-switch-generator-start-stop [2019-01-28 06:40] – [1.1 MultiPlus and Quattro models of 3000VA and above] guy_stewart | ve.bus:virtual-switch-generator-start-stop [2019-01-29 12:02] – [1.4 MultiPlus Compact models] guy_stewart | ||
===== Virtual switch - Generator start/stop ===== | ===== Virtual switch - Generator start/stop ===== | ||
- | This document explains one of the ways to automatically start and stop a generator. See [[auto-generator-start-stop: | + | This document explains |
- | More generator | + | More general |
===== 1. Wiring ===== | ===== 1. Wiring ===== | ||
Line 11: | Line 11: | ||
==== 1.1 MultiPlus and Quattro models of 3000VA and above ==== | ==== 1.1 MultiPlus and Quattro models of 3000VA and above ==== | ||
- | To do the wiring easily; be aware that its detachable: you can pull the block off; do the wiring; | + | Be aware that this relay block is detachable. You can pull the block off, removing it from the board. This makes it easier to wire connections, |
Note that there are three contacts; left to right: Normally Closed (NC) , Normally Open (NO), Common (COM). | Note that there are three contacts; left to right: Normally Closed (NC) , Normally Open (NO), Common (COM). | ||
Line 21: | Line 21: | ||
==== 1.2 MultiPlus-II models ==== | ==== 1.2 MultiPlus-II models ==== | ||
- | The connector | + | The contact order for Multiplus-II |
- | {{ :ve.bus:capture2.gif?600 |}} | + | {{:ve.bus:victron_multi2_relay.jpg?direct&600|}} |
==== 1.3 MultiPlus 500VA to 1600VA models ==== | ==== 1.3 MultiPlus 500VA to 1600VA models ==== | ||
- | And, on our Multi 500, 800, 1200 and coming 1600, is contact E; here: | + | On our Multi 500, 800, 1200 and coming 1600, the order from left to right is COM, NC, NO. |
+ | Contact | ||
==== 1.4 MultiPlus Compact models ==== | ==== 1.4 MultiPlus Compact models ==== | ||
- | {{ :ve.bus:multiplus-compact.png?600 |}} | + | This relay block is also removable (by pulling) for easier wiring. |
+ | Contact order is NO, COM, NC | ||
+ | {{:ve.bus:victron_multicompact_relay_3_close.jpg?direct&600|}} | ||
===== 2. Configuration ===== | ===== 2. Configuration ===== | ||
- | ==== 2.1 enable | + | ==== 2.1 Enable |
Open VEConfigure, | Open VEConfigure, | ||
Line 43: | Line 51: | ||
- | ==== 2.2 configure | + | ==== 2.2 Configure |
Note that below are just example values; configure them to the match the type of batteries and rest of system. | Note that below are just example values; configure them to the match the type of batteries and rest of system. | ||
Line 50: | Line 58: | ||
ve.bus/virtual-switch-generator-start-stop.txt · Last modified: 2019-09-13 14:03 by marmour
