ve.bus:ve.bus_error_codes
ve.bus:ve.bus_error_codes [2021-03-20 02:45] – guystewart | ve.bus:ve.bus_error_codes [2022-03-03 11:21] – [Error 3 - Not all, or more than, the expected devices were found in the system] mvader | ||
Line 9: | Line 9: | ||
- | *WARNING*: The steps and instructions explained here, are intended to be carried to be carried out by trained professionals. AC (and also DC) Voltages can be lethal. And certain settings and firmware updates require experience and training as well. | + | **WARNING**: The steps and instructions explained here, are intended to be carried to be carried out by trained professionals. AC (and also DC) Voltages can be lethal. And certain settings and firmware updates require experience and training as well. |
==== Network cable quality ==== | ==== Network cable quality ==== | ||
Line 30: | Line 30: | ||
Note for split- and three-phase systems: VRM, nor the GX device, will indicate on which phase the overload or the temperature alarm occured. To find out on which unit the error occurs, go to system after it has switched off. And look on the LEDs. The unit with the overload or temperature alarm, will have the corresponding alarm LED lit continuously. The other units will indicate a VE.Bus error, indicating that they miss one unit. | Note for split- and three-phase systems: VRM, nor the GX device, will indicate on which phase the overload or the temperature alarm occured. To find out on which unit the error occurs, go to system after it has switched off. And look on the LEDs. The unit with the overload or temperature alarm, will have the corresponding alarm LED lit continuously. The other units will indicate a VE.Bus error, indicating that they miss one unit. | ||
- | ==== Error 2 - New and old types MK2 are mixed in the system ==== | + | __Recovery: |
+ | ==== Error 2 - New and old type MK2 protocol | ||
+ | __Recovery: | ||
Line 40: | Line 45: | ||
- Communication cable error: Check the communication cables. Make sure to use commercial patch leads and not hand-crimped cables - VE.Bus cabling is very sensitive to physical wiring faults. | - Communication cable error: Check the communication cables. Make sure to use commercial patch leads and not hand-crimped cables - VE.Bus cabling is very sensitive to physical wiring faults. | ||
- | - DC fuse blown of one or more units in the system: When mains is available all units seems to work correctly, but as soon as mains fails, or as soon as the system decides to switch to Island mode for any other reason, the non powered | + | - DC fuse blown of one or more units in the system: When mains is available all units seems to work correctly. But as soon as mains fails, or as soon as the system decides to switch to Island mode for any other reason, the units with the blown DC fuse will be without power and switched off - and thus be " |
Line 55: | Line 62: | ||
Line 60: | Line 69: | ||
Line 69: | Line 80: | ||
- | ==== Error 7 - VE.Bus BMS detected, but not configured ==== | + | This error can also occur in newer firmwares when a VE.Bus BMS is connected |
- | Solution: configure the use of the VE.Bus BMS in one of the Assistants. | + | __Recovery:__ auto-restart once the error is gone. |
+ | ==== Error 7 - External device connected, assistant required ==== | ||
+ | An external device (e.g. a VE.Bus BMS) is connected but there is no Assistant loaded which handles that device. | ||
+ | Solution: configure the Multi/ | ||
==== Error 8 - Ground relay test failed ==== | ==== Error 8 - Ground relay test failed ==== | ||
- | Indicates | + | This error indicates |
+ | | MultiPlus-II 48V 3kVA | HQ2048 | | ||
+ | | MultiPlus-II 48V 3kVA GX | HQ2050 | | ||
+ | | MultiPlus-II 24V 3kVA | HQ2101 | | ||
+ | | MultiPlus-II 48V 5kVA | HQ2116 | | ||
+ | | MultiPlus-II 48V 5kVA GX | HQ2122 | | ||
+ | | EasySolar-II 48V 3kVA MPPT 250-70 GX | HQ2130 | | ||
- | See Error 11 for details & instructions. | + | This issue affects three phase systems only. |
Line 93: | Line 193: | ||
Other possibility: | Other possibility: | ||
DC fuse blown of one or more units in the system. When mains is available all units seems to work correctly, but as soon as mains fails, the non powered units are disconnected from the system. | DC fuse blown of one or more units in the system. When mains is available all units seems to work correctly, but as soon as mains fails, the non powered units are disconnected from the system. | ||
==== Error 11 - Relay Test Fault - Installation error or possibly relay failure ==== | ==== Error 11 - Relay Test Fault - Installation error or possibly relay failure ==== | ||
Line 99: | Line 201: | ||
If a grid code is selected in VEConfigure, | If a grid code is selected in VEConfigure, | ||
- | Ground relays are also tested and can trigger an Error 8. During inverter operation, disconnected from mains, the relay is continuously tested to be closed. And it is tested to open properly during switchover to mains. The ground relay tests are always performed: with or without a configured grid code. Unless the relay is disabled in VEConfigure. See product manual for more information regarding the ground relay. | ||
=== Steps to take: === | === Steps to take: === | ||
Line 112: | Line 212: | ||
Step 4: Check your Neutral-out connection. In most cases there should be no external connection between ACin-Neutral to ACout-Neutral, | Step 4: Check your Neutral-out connection. In most cases there should be no external connection between ACin-Neutral to ACout-Neutral, | ||
- | In Australia, it is possible if required | + | In Australia, using grid code AS4777.2: |
Line 133: | Line 233: | ||
* A six digit number; which contains all the details | * A six digit number; which contains all the details | ||
- | * An error ID (#16 for example). Note that this does not count the the number of VE.Bus errors; its just a unique ID that can help recognizing that a new error has occured. | + | * An error ID (#4 in above screenshot). Note that this does not count the number of VE.Bus errors; its just a unique ID that can help recognizing that a new error has occurred. |
* Flags | * Flags | ||
* The failed step; it counts backwards: step 9 -> 8 -> 7 and so forth. | * The failed step; it counts backwards: step 9 -> 8 -> 7 and so forth. | ||
Line 140: | Line 240: | ||
* Failing step #8: check that line and neutral have not been swapped. Unlike non-grid code installations; | * Failing step #8: check that line and neutral have not been swapped. Unlike non-grid code installations; | ||
- | * PE2 closed error or GND Relay Error: check that AC-out Neutral is not wired to ground, or AC-in Neutral + ground. Short circuiting them is not allowed without specific firmware and grid code. Also, check that there is no leakage between Neutral and ground, for example because broken consumer. Start by disconnecting all loads: open all the circuit breakers. Then test to confirm there is no continuity between ACin-Neutral and ACout-Neutral. | ||
* AC0/AC1 mismatch and UMains error: this is fixed in VE.Bus inverter/ | * AC0/AC1 mismatch and UMains error: this is fixed in VE.Bus inverter/ | ||
- | Other shown error details, listed below, are not related to any known installation issue and can be caused by a faulty unit or configuration issue. In any case, also when one of below errors shows, to go through all the above steps for any error 11 issue. | + | Other shown error details, listed below, are not related to any known installation issue and can be caused by a faulty unit or configuration issue. In any case, also when one of below errors shows, |
* Failing steps #2-7. | * Failing steps #2-7. | ||
Line 151: | Line 250: | ||
* Period Time mismatch. | * Period Time mismatch. | ||
* Drive of BF relay mismatch. | * Drive of BF relay mismatch. | ||
- | * PE2 open error. | ||
=== Unable to solve? === | === Unable to solve? === | ||
When the error persists after the all above steps, or when any other Failed step or extra explanation shows, then the unit may be faulty. Follow the [[https:// | When the error persists after the all above steps, or when any other Failed step or extra explanation shows, then the unit may be faulty. Follow the [[https:// | ||
==== Error 12 - Config mismatch with 2nd mcu ==== | ==== Error 12 - Config mismatch with 2nd mcu ==== | ||
Line 166: | Line 267: | ||
Make sure to select the option 'all settings' | Make sure to select the option 'all settings' | ||
Line 171: | Line 275: | ||
+ | Any combination error of VE.Bus products, firmware versions or commands has occured | ||
+ | * an Interface-1140 with old firmware is combined with a new Multi firmware or | ||
+ | * when external BMS commands are send while a VE.Bus BMS is connected or | ||
+ | * the connected VE.Bus product firmware versions are incompatible. (This can in most cases be solved by updating the firmware.) | ||
Line 176: | Line 292: | ||
==== Error 17 - Phase master missing ==== | ==== Error 17 - Phase master missing ==== | ||
Line 193: | Line 311: | ||
=== Unable to solve it? === | === Unable to solve it? === | ||
If after all above steps you are still experiencing a VE.Bus Error 17, contact your dealer whom will contact Victron repairs; please provide photos of the installation and network cabling. Depending on the situation, they might advice to replace the [[venus-os: | If after all above steps you are still experiencing a VE.Bus Error 17, contact your dealer whom will contact Victron repairs; please provide photos of the installation and network cabling. Depending on the situation, they might advice to replace the [[venus-os: | ||
==== Error 19 - Slave does not have AC input! ==== | ==== Error 19 - Slave does not have AC input! ==== | ||
Line 202: | Line 324: | ||
Solution: Either connect the AC input to all units, or change the configuration of the synchronised units in VE.Bus System Configurator (note not VEConfigure), | Solution: Either connect the AC input to all units, or change the configuration of the synchronised units in VE.Bus System Configurator (note not VEConfigure), | ||
Line 212: | Line 344: | ||
What is the back-feed relay? It is the relay that closes when connecting to the grid or generator. And which opens when there is no power available, ie when the system is in island- or invert-mode. | What is the back-feed relay? It is the relay that closes when connecting to the grid or generator. And which opens when there is no power available, ie when the system is in island- or invert-mode. | ||
- | Error 24 is raised when a Multi or Quattro detects current flowing through the back-feed relay during a period when the relay should be open. This can mean one of two things: | + | Error 24 is raised when a Multi or Quattro detects current flowing through the back-feed relay during a period when the relay should be open. This can mean one of three things: |
- The relay did not open. | - The relay did not open. | ||
- The related current measurement circuit is faulty. | - The related current measurement circuit is faulty. | ||
+ | - A multiplus II is used with an external current sensor connected, but the option ' | ||
Error 24 is a very rare error. Possible causes in order of probability: | Error 24 is a very rare error. Possible causes in order of probability: | ||
+ | * (only on MP II models when using external sensor) the option ' | ||
* There is too much AC load connected at the moment the relay needs to switch off. This large current will prevent the relay contacts from opening.\\ __Solution__: | * There is too much AC load connected at the moment the relay needs to switch off. This large current will prevent the relay contacts from opening.\\ __Solution__: | ||
* The AC input voltage slowly drops before it is being rejected by the Multis. Typically happens in installations with a generator. Especially when combined with AC loads that increase their current draw when the AC voltage drops: by the time that the inverter/ | * The AC input voltage slowly drops before it is being rejected by the Multis. Typically happens in installations with a generator. Especially when combined with AC loads that increase their current draw when the AC voltage drops: by the time that the inverter/ | ||
Line 246: | Line 380: | ||
Good units will measure discontinuity between the Line in and out terminals. And measure a few hundred ohms between the neutral In and Out AC terminals. | Good units will measure discontinuity between the Line in and out terminals. And measure a few hundred ohms between the neutral In and Out AC terminals. | ||
==== Error 25 - Firmware incompatibility ==== | ==== Error 25 - Firmware incompatibility ==== | ||
Line 252: | Line 388: | ||
Solution: update all devices to the latest available firmware. Instructions [[updating_firmware: | Solution: update all devices to the latest available firmware. Instructions [[updating_firmware: | ||
Should not occur. Switch all equipment off, and then on again; it will then resume operation. Contact Victron Energy if the problem persists. | Should not occur. Switch all equipment off, and then on again; it will then resume operation. Contact Victron Energy if the problem persists. | ||
~~DISQUS~~ | ~~DISQUS~~ |
ve.bus/ve.bus_error_codes.txt · Last modified: 2023-06-27 09:34 by jpasop
