ve.bus:ve.bus_error_codes
Last revision Both sides next revision
ve.bus:ve.bus_error_codes [2019-05-18 07:13]
mvader [Error 17 - Original Master Missing]
ve.bus:ve.bus_error_codes [2019-11-11 06:09]
127.0.0.1 external edit
 ====== VE.Bus Error Codes ====== ====== VE.Bus Error Codes ======
 ===== General ===== ===== General =====
-During first installation,​ and in case of problems, update all devices to the latest firmware. This includes the latest VE.Bus firmware and also the latest firmware in the Color Control ​GX. +During first installation,​ and in case of problems, update all devices to the latest firmware. This includes the latest VE.Bus firmware and also the latest firmware in the [[venus-os:​start|GX device]]
 Firmware update instructions:​ Firmware update instructions:​
Line 8: Line 8:
 To restart a system, first switch all units off, one by one. And then switch all units on again. Do this with the On / Off / Charger-only rocker-switch on the front of the device. To restart a system, first switch all units off, one by one. And then switch all units on again. Do this with the On / Off / Charger-only rocker-switch on the front of the device.
 +*WARNING*: The steps and instructions explained here, are intended to be carried to be carried out by trained professionals. AC (and also DC) Voltages can be lethal. And certain settings and firmware updates require experience and training as well.
 ==== Network cable quality ==== ==== Network cable quality ====
Line 37: Line 39:
   - This error often follows VE.Bus Error 1. Solution: solve the cause for VE.Bus Error 1. Note that when using an older CCGX (version before v1.40), ​ it can be that the first error is not reported on the Alarm log on VRM. So even when it only lists VE.Bus Error 3, it can very well be that that error was preceeded by VE.Bus Error 1.   - This error often follows VE.Bus Error 1. Solution: solve the cause for VE.Bus Error 1. Note that when using an older CCGX (version before v1.40), ​ it can be that the first error is not reported on the Alarm log on VRM. So even when it only lists VE.Bus Error 3, it can very well be that that error was preceeded by VE.Bus Error 1.
   - The system is not properly configured: all VE.Bus devices connected to the VE.Bus network must be configured as one parallel, split- and/or three-phase system. Do not connect two separate VE.Bus systems together.   - The system is not properly configured: all VE.Bus devices connected to the VE.Bus network must be configured as one parallel, split- and/or three-phase system. Do not connect two separate VE.Bus systems together.
-  - Communication cable error: ​check the communication cables.+  - Communication cable error: ​Check the communication cables. ​Make sure to use commercial patch leads and not hand-crimped cables - VE.Bus cabling is very sensitive to physical wiring faults.
 +  - DC fuse blown of one or more units in the system: When mains is available all units seems to work correctly, but as soon as mains fails, or as soon as the system decides to switch to Island mode for any other reason, the non powered units are disconnected from the system.
 ==== Error 4 - No other device found ==== ==== Error 4 - No other device found ====
Line 69: Line 73:
 Solution: configure the use of the VE.Bus BMS in one of the Assistants. Solution: configure the use of the VE.Bus BMS in one of the Assistants.
 +==== Error 8 - Ground relay test failed ====
 +Indicates a failed automatic Ground relay self-test on the MultiPlus-II or EasySolar-II relays.
 +See Error 11 for details & instructions.
 ==== Error 10 - System time synchronisation problem ==== ==== Error 10 - System time synchronisation problem ====
Line 80: Line 90:
 Note: System restarts can also be triggered when using Remote VEConfigure. Note: System restarts can also be triggered when using Remote VEConfigure.
 +Other possibility: ​
 +DC fuse blown of one or more units in the system. When mains is available all units seems to work correctly, but as soon as mains fails, the non powered units are disconnected from the system.
 ==== Error 11 - Relay Test Fault - Installation error or possibly relay failure ==== ==== Error 11 - Relay Test Fault - Installation error or possibly relay failure ====
-This error only applies to the MultiGrid, ​MultiPlus-IIEasySolar-II ​and other inverter/​chargers with a dual backfeed relayAs part of grid-code compliance; ​the device tests verifies that its internal ​relays ​function ​properly.+Error 11 indicates a failed automatic self-test of the MultiPlus-II ​or EasySolar-II ​relaysIt is often a result ​of an installation or wiring issue, though it can also be triggered by a hardware failure (eg inoperable relays).
 +If a grid code is selected in VEConfigure,​ then the backfeed ​relays ​are tested every time before connecting to the mains.
 +Ground relays are also tested and can trigger an Error 11. During inverter operation, disconnected from mains, the relay is continuously tested to be closed. And it is tested to open properly ​during switchover to mainsThe ground relay tests are always performed: with or without a configured grid code. Unless the relay is disabled in VEConfigure. See product manual for more information regarding the ground relay.
 +=== Steps to take: ===
-The relays are tested when a grid code is selected ​in VEConfigureWhen the grid-code is set to Nonethe tests are not performed.+Step 1: Make sure that the units have been [[updating_firmware:​updating_ve.bus_products|updated to the latest firmware version]]. There have been various VE.Bus error 11 related improvements ​in the firmwareThis may correct ​the errorand if it does not, it will provide additional information to assist troubleshooting.
-When VE.Bus error 11 shows, either ​the back-feed relay test, ground relay test, or measurement redundancy tests has failedThe tests are automatically performed every time before connecting ​to mains.+Step 2: Verify that system is properly wired to your installation and your local codesRemember to check the earth connection on the unit AC inputEarth should be grounded according ​to your local grid rules. Do not connect Earth to Neutral in the unit itself. This will create a safety hazard and may prevent RCD devices from working. Contact another licensed electrician if in doubt
-The three root causes ​of the error can be (from most common to least common):+Step 3: Disconnect the L and N wiring from the ACout terminals on each inverter/​charger. Which, in case of a parallel or three phase system, isolates ​the ACout connections for each unit. If the system then starts normally there might be a problem with a connected load (e.g. a leakage between load, neutral and ground).
-1) In most cases, when you see Error 11, its due to an installation error:\\  +Step 4Check your Neutral-out connection. ​In most cases there should be no external connection between ​ACin-Neutral to ACout-Neutral,​ or to Earth. ​
-  * Please verify that the neutral is connected to earth on the supply side. In many countries this is done by the utility in the transformer cabinet (a TN network). +
-  * Line should be connected to the corresponding Line input on the inverter/​charger,​ same for Neutral. A swapped ​connection ​results in Error 11. +
-  * There should be no external connection between ​N-out and GND+
-2) For Australia: ​contact your distributor.+In Australia, it is possible if required to install with a connection between Neutral-in and Neutral-out using AS4777.2:2015. Select either design configuration in the grid code section while programming the MultiPlus-II with firmware 466 and above. After configuration,​ always confirm that the system is safe with routine electrical safety checks in both modes (eg test RCD operation with AC input connected and disconnected).
-3) Hardware defect; contact your distributor for a replacement.+Step 5: Neutral and line input might be inverted. Check the input connections,​ swap them if needed and retry. In this case, “Failing step: 8” will show.
 === Detailed diagnosis of Error 11 === === Detailed diagnosis of Error 11 ===
-After updating your VE.Bus inverter/​charger to firmware 454 or higher; and running Venus OS v2.23 or later, a detailed VE.Bus Error report can be seen in the Venus-device menu. The information shown is:
-It shows:+After updating your VE.Bus inverter/​charger to firmware 454 or higher; and running Venus OS v2.23 or later, a detailed VE.Bus Error 11 report is available in the GX device menu, under MultiPlus -> Alarm Status -> VE.Bus Error 11 report.
 +Examples of information in the GX Device menus:
 +{{:​ve.bus:​error11-ccgx3.jpg?​nolink|}}
 +{{:​ve.bus:​error11-ccgx4.jpg?​nolink|}}
 +The information shown is:
   * A six digit number; which contains all the details   * A six digit number; which contains all the details
   * An error ID (#16 for example). Note that this does not count the the number of VE.Bus errors; its just a unique ID that can help recognizing that a new error has occured.   * An error ID (#16 for example). Note that this does not count the the number of VE.Bus errors; its just a unique ID that can help recognizing that a new error has occured.
Line 112: Line 136:
   * Failing step #8: check that line and neutral have not been swapped. Unlike non-grid code installations;​ line and neutral need to be wired correctly.   * Failing step #8: check that line and neutral have not been swapped. Unlike non-grid code installations;​ line and neutral need to be wired correctly.
-  * PE2 open error: check that AC-out Neutral is not wired to Ground. Short circuiting them is not allowed. Also, check that there is no leakage between Neutral and ground, for example because broken consumer. Start by disconnecting all loads: open all the circuit breakers. +  * PE2 closed ​error or GND Relay Error: check that AC-out Neutral is not wired to ground, or AC-in Neutral + ground. Short circuiting them is not allowed ​without specific firmware and grid code. Also, check that there is no leakage between Neutral and ground, for example because broken consumer. Start by disconnecting all loads: open all the circuit breakers. Then test to confirm there is no continuity between ACin-Neutral and ACout-Neutral
-  * AC0/AC1 mismatch and UMains error: ​there has been a fix for that in VE.Bus inverter/​charger firmware version 455.+  * AC0/AC1 mismatch and UMains error: ​this is fixed in VE.Bus inverter/​charger firmware version 455.
 +Other shown error details, listed below, are not related to any known installation issue and can be caused by a faulty unit or configuration issue. In any case, also when one of below errors shows, to go through all the above steps for any error 11 issue.
 +  * Failing steps #2-7.
 +  * AC0 /AC1 mismatch.
 +  * Communication error.
 +  * UMains mismatch.
 +  * Period Time mismatch.
 +  * Drive of BF relay mismatch.
 +  * PE2 open error.
 +=== Unable to solve? ===
-In all other cases, contact your Victron representative for supportPlease ​provide a photo of the error; and otherwise at least the 6 digit number at the top.+When the error persists after the all above steps, or when any other Failed step or extra explanation showsthen the unit may be faulty. Follow the [[https://​www.victronenergy.com/​support|support procedure and contact your dealer.]] Make sure to document full system wiring in a diagram, all steps and tests taken to diagnose and rule out installation error, and provide a photo of the error details shown on the GX Device menu.
 +==== Error 12 - Config mismatch with 2nd mcu ====
-The report is found by navigating to the Device list (top level menu), then going in to the Multi or Quattro inverter/​charger page, then to the bottom, Alarm Status, then to the bottom again, in to the menu VE.Bus Error 11 report.+Some Multi models (e.g. MultiPlus-II) have two microcontrollers.
-Now you will see a list of all devices ​in the system; ​and their latest VE.Bus Error 11 details. Enter the menu for an explanation of the code.+Certain configuration settings, as done with VEConfigure,​ have to be stored ​in both microcontrollers.
 +In very rare situations it can happen that the stored configurations do not match and that the mismatch cannot be handled automaticallyIn this case error E12 will be generated.
-{{ :ve.bus:​error11-ccgx3.jpg?​nolink |}} +To solve this error, connect the device to VEConfigure 3, verify/​correct the settings and press 'Send Settings'​.
-{{ :​ve.bus:​error11-ccgx4.jpg?​nolink |}}+
 +Make sure to select the option 'all settings'​ instead of '​modified settings'​.
 ==== Error 14 - Device cannot transmit data ==== ==== Error 14 - Device cannot transmit data ====
Line 135: Line 173:
 Instructions [[updating_firmware:​updating_ve.bus_products|here]]. Instructions [[updating_firmware:​updating_ve.bus_products|here]].
-==== Error 17 - Original Master Missing ​====+==== Error 17 - Phase master missing ​====
 +Error 17 shows on slaves (only). The slaves in a system will report this error when the communication with the phase-master has timed out.
 This error can only occur on systems with multiple devices installed per phase. For example a single phase installation with two or more devices in parallel, or a three-phase installation with six or more devices. ​ This error can only occur on systems with multiple devices installed per phase. For example a single phase installation with two or more devices in parallel, or a three-phase installation with six or more devices. ​
-Error 17 will only appear ​on slavesYou'll see it when its phase-master ​is no longer ​communicating ​on the VE.Bus network.+Steps to take:
 +  - In some cases this error can be seen temporarily while using Remote VEConfigure to write a new configuration. \\ __Solution__:​ ignore the error; the system ​will recover by itself.
 +  - The most likely cause is a cable-related communication issue on the VE.Bus network: \\ __Solution__:​ First check the network cables sockets. If that doesn't solve it, replace all network cables, including the cable to the [[venus-os:start|GX Device]]. Make sure to also inspect the female RJ-45 sockets, instead of only the cabling: sometimes badly mounted RJ45 cable connectors prevent the spring-contacts in the female RJ45 connectors on the Multis to properly make contact. Make sure to machine-made cabling. Do not use self-crimped cables.
 +  - DC fuse blown. In this case, all units can in some situations seem fine and work well as long as mains is available. And then when there is no longer ​AC available ​on the input (mains fails or generator is stopped) the non powered units are disconnected from the system\\ __Solution__:​ Check the fuse in all units; replace the broken one.
 +  - Update firmware and Assistants of the inverter/​chargers. And of the GX Device. \\ __Solution__:​ [[updating_firmware:​updating_ve.bus_products|Update the Inverter/​charger firmware]] - [[assistants:​how_to_update_an_assistant|Update the Assistants]] - [[ccgx:​firmware_updating|Update the GX Device firmware]].
 +=== Systems with multiple slaves per phase ===
 +Error 17 can show on one or more slaves in a phase (visible by looking at the LEDs, not on VRM or GX Device). If the slaves can still communicate with each other; then the error will only show on one slave: all slaves that can see on the network ​that another slave is already showing Error 17 will not show the error as well.
-  * In some cases this error can be seen temporarily while using Remote VEConfigure ​to write new configuration. +=== Unable ​to solve it? ===
-  * Otherwise, the most likely cause is bad cabling/​contacts ​on the VE.BusCheck cabling ​and contactsMake sure to also inspect the female RJ-45 socketsinstead of only the cabling: Sometimes badly mounted RJ45 cable connectors prevent the spring-contacts in the female RJ45 connectors on the Multis to properly make contact.+If after all above steps you are still experiencing ​VE.Bus Error 17contact your dealer whom will contact Victron repairs; please provide photos of the installation and network ​cabling. Depending ​on the situation, they might advice to replace the [[venus-os:start|GX device]] ​and the inverter/​chargersWe advise ​to first replace cablesand if that doesn'​t help then thereafter ​only the GX device at first, since that is less work than replacing ​the inverter/​chargers.
 ==== Error 18 - AC Over-voltage on the output of a slave while switched off ==== ==== Error 18 - AC Over-voltage on the output of a slave while switched off ====
Line 165: Line 212:
   * The AC input voltage slowly drops before it is being rejected by the Multis. Typically happens in installations with a generator. Especially when combined with AC loads that increase their current draw when the AC voltage drops: by the time that the inverter/​charger initiates the disconnect, the current through the relays has increased well beyond the ratings, and is too high to open them.\\ __Solution__:​ Make the Multis or Quattros disconnect earlier: increase lower limit of AC input voltage in VEConfigure3. For example to 210 VAC. The factory setting is 180 VAC.   * The AC input voltage slowly drops before it is being rejected by the Multis. Typically happens in installations with a generator. Especially when combined with AC loads that increase their current draw when the AC voltage drops: by the time that the inverter/​charger initiates the disconnect, the current through the relays has increased well beyond the ratings, and is too high to open them.\\ __Solution__:​ Make the Multis or Quattros disconnect earlier: increase lower limit of AC input voltage in VEConfigure3. For example to 210 VAC. The factory setting is 180 VAC.
   * The back-feed relay has a hardware failure \\ __Solution__:​ Replace faulty unit.   * The back-feed relay has a hardware failure \\ __Solution__:​ Replace faulty unit.
-  * The related current measurement circuit is faulty. \\ __Solution__: ​replace ​faulty unit.+  * The related current measurement circuit is faulty. \\ __Solution__: ​Replace ​faulty unit.
-__How to determine which unit raised the error in a parallel, multi or split-phase system?__+__Diagnosing ​a parallel, multi or split-phase system?__
-First, ​always ​double check option 1 and 2 in above list. Those are the common causesIn case that doesn'​t lead to solutionfollow this procedure ​to see which unit raises ​the error.+Error 24 will always ​appear on all units at the same timeThere is unfortunately no indication, not on LEDs, nor on GX device, VRM, or any other manner, to see which of the devices caused ​the error. Below procedures outlines how to manually determine which unit has a faulty relay.
-In any installation with more than one unitit is not possible to identify which one triggered the errorError 24 will always appear on all units at the same timeThere is no indicationnot on LEDs, nor on GX device or any other mannerto see which unit raised ​the error.+Do make sure to firstalways double check option 1 and 2 in above listThose are the common causesIn case that doesn'​t lead to a solutionfollow this procedure to find out if its relay issueand then which unit
 +Execute this procedure right after the error occurred; do not first reset the system
 __Step 1__ __Step 1__
-Right after the error occurred, make a video of all units and their LED code. Do not first reset the system; and do not reset it after making the video either.+Start with making ​a video of all units and their LED code. Do not first reset the system; and do not reset it after making the video either.
 __Step 2__ __Step 2__
Line 200: Line 249:
 ~~DISQUS~~ ~~DISQUS~~
ve.bus/ve.bus_error_codes.txt · Last modified: 2019-12-10 00:44 by guy_stewart
