(draft)
Reason for this page is that we'll add a link into VEConfigure (& VictronConnect) to explain a new feature that is being added.
Which makes the inverter/charger charge up to float voltage only, to prioritise renewable energy.
To be detailed in more detail later.
Target: boats, campers, and so forth that want their solar charger to take care of most of charging when connected to shore power; either while travelling but also when back home. And that want the Multi to be there as a backup to make sure batteries are not left alone in case there is no or not enough charger; and want an option in their enduser-controls to force a charge whenever they need it.
Details:
- for a Quattro, this will only work when connected to AC-in-2, since AC-in-1 is where a generator is connected and while that is running you want to charge with full power. - if storage is enabled in its settings, then after a hardcoded 12 hours go to storage
Add this page to your book
Manage book (
Help
