ve.bus:manual_parallel_and_three_phase_systems [2020-03-09 02:39] – external edit 127.0.0.1 | ve.bus:manual_parallel_and_three_phase_systems [2025-05-21 10:50] (current) – mvader | ||
- | This manual explains the details of designing, installing and configuring three-phase and parallel systems. It applies to components that use VE.Bus, for example MultiPlus, Quattro and some larger | + | This manual explains the details of designing, installing and configuring three-phase and parallel systems. It applies to components that use VE.Bus, for example, MultiPlus, Quattro and some larger |
- | * Note that some parts of the description below apply only to 4xx firmwares. | + | * Note that some parts of the description below apply only to firmware version 400 and later. |
- | * All units in one system must be the same type and firmware version, this includes same size, system voltage, and feature set. The type is indicated by the first four digits of the firmware version number. For details, see the " | + | * All units in one system must be the same type and firmware version; this includes same size, system voltage, and feature set. The type is indicated by the first four digits of the firmware version number. For details, see the " |
+ | * MultiPlus-II 8k, 10k, and 15k models can only be connected in parallel if an external AC transfer switch is used. For more information see the [[https:// | ||
Line 14: | Line 18: | ||
+ | These should | ||
First get experience with smaller systems. If you are new to Victron, please start with simpler designs, so that you become familiar with the necessary training, equipment and software required. | First get experience with smaller systems. If you are new to Victron, please start with simpler designs, so that you become familiar with the necessary training, equipment and software required. | ||
Line 28: | Line 33: | ||
Line 40: | Line 45: | ||
+ | === Main text === | ||
Line 46: | Line 52: | ||
For units in parallel: Both the DC and AC wiring needs to be symmetrical per phase: use the same length, type and cross-section to every unit in the phase. To make this easy, use a bus-bar or power-post before and after the inverter/ | For units in parallel: Both the DC and AC wiring needs to be symmetrical per phase: use the same length, type and cross-section to every unit in the phase. To make this easy, use a bus-bar or power-post before and after the inverter/ | ||
- | With regards to AC fusing, each unit needs to be fused individually. Both on its AC-out and AC-in. Multiple circuit breakers which are mechanically connected together is OK: that is also one fuse. Make sure to use the same type of fuse on each unit due to same resistance. | + | With regards to AC fusing, each unit needs to be fused individually. Make sure to use the same type of fuse on each unit due to same resistance. Consider using mechanically connected fuses, so that if one trips, they all trip - leading to a clear fault. |
With regards to DC fusing, each unit needs to be fused individually. Make sure to use the same type of fuse on each unit due to same resistance. | With regards to DC fusing, each unit needs to be fused individually. Make sure to use the same type of fuse on each unit due to same resistance. | ||
Line 54: | Line 60: | ||
- | Note: Do not over-dimension the AC cabling. Using extra thick cabling has negative side effects.\\ | + | === Warning against over-dimensioning the AC wiring === |
- | | + | Note: Do not over-dimension the AC cabling. Using extra thick cabling has negative side effects. |
- | * Using 2 units (A and B) parallel and using extremely | + | |
- | * Using the same 2 units in parallel with bad AC cabling one might end up with a total resistance for Unit_A of 15Ω and a total resistance for Unit_B of 16Ω. This results in a much better current distribution (Unit_A will carry 1.066 times more current than Unit_A) even if the absolute difference in resistance is much bigger than in the previous example (1Ω vs 0.0001Ω). | + | Technical background: |
- | ==== A continuous, unbroken negative link must be maintained between all units ==== | + | |
+ | An exaggerated example: | ||
+ | * Using the same 2 units in parallel with, for the sake of this example underdimensioned | ||
- | VE.Bus is not isolated on the MultiPlus range and Quattros. | + | A side effect of over dimensioning the AC cabling can be faulty Power Assist operation. Out of all units, |
- | Therefore it is very important to prevent damage to the communications cards that the negative battery terminal of a Quattro remains continuous between units as long as the VE.Bus cable that connects the multiple units is connected. | + | === Delta configurations not supported === |
- | If units need to be isolated at both poles, or local wiring requirements demand double pole isolation | + | For units in 3 phase configuration: |
- | Double pole isolation of the system is allowed (and sometimes required), as long as it at the battery connection end of the DC bus, and the Multis/ | ||
- | ==== Theory and background information ==== | + | === Theory and background information ==== |
- | wiring | + | Wiring |
Line 81: | Line 90: | ||
Line 96: | Line 105: | ||
* All charger settings, such as absorption voltage, float voltage and max charge current.\\ (The maximum charge current is multiplied by the number of units in the system: in a 9 unit system set it to 50A to get a 450A maximum charge current.) | * All charger settings, such as absorption voltage, float voltage and max charge current.\\ (The maximum charge current is multiplied by the number of units in the system: in a 9 unit system set it to 50A to get a 450A maximum charge current.) | ||
* System frequency | * System frequency | ||
- | * Whether or not "Weak LOM" is used | ||
- | * Input current limits\\ (the effective input current limit is the setted | + | * Input current limits\\ (the effective input current limit is the limit set on the master |
+ | * Weak AC input on/off | ||
Line 121: | Line 130: | ||
* If you are using a self-consumption assistant, such as ESS, Hub-1 to Hub-4, the assistant will need to be loaded into each unit in the system individually.\\ | * If you are using a self-consumption assistant, such as ESS, Hub-1 to Hub-4, the assistant will need to be loaded into each unit in the system individually.\\ | ||
- | * The VE.Bus BMS and the Two-Signal BMS support Assistant also need to be loaded in each unit in the system. | + | * The VE.Bus BMS and the Two-Signal BMS support Assistant also need to be loaded in each unit in the system |
- | (nb: In some cases (depending on the choices made) slaves can be left out, the assistant | + | * For the [[https:// |
- | Tip: a quick way to load Assistants into each unit in the system is to save the settings after configuring the master in L1. Then open VEConfigure for another unit and load that file. VEConfigure will automatically adapt the Assistants for the slaves. (note: In some cases you might get some warnings. Please step through the assistant in that case.) | ||
Line 140: | Line 149: | ||
===== Training Video ===== | ===== Training Video ===== | ||
- | There is an advanced training video and competency exam for 3 phase and parallel installation and commissioning available on [[https:// | + | There is an advanced training video and competency exam for 3 phase and parallel installation and commissioning available on [[https:// |
ve.bus/manual_parallel_and_three_phase_systems.1583717946.txt.gz · Last modified: by 127.0.0.1
