ve.bus:manual_parallel_and_three_phase_systems [2019-09-24 12:54] – guy_stewart | ve.bus:manual_parallel_and_three_phase_systems [2024-02-09 13:07] (current) – Removed “Weak LOM” setting. since that is currently the default jpasop | ||
- | This manual explains the details of designing, installing and configuring three-phase and parallel systems. It applies to components that use VE.Bus, for example MultiPlus, Quattro and some larger | + | This manual explains the details of designing, installing and configuring three-phase and parallel systems. It applies to components that use VE.Bus, for example, MultiPlus, Quattro and some larger |
- | * Note that some parts of the description below apply only to 4xx firmwares. | + | * Note that some parts of the description below apply only to firmware version 400 and later. |
- | * All units in one system must be the same type and firmware version, this includes same size, system voltage, and feature set. The type is indicated by the first four digits of the firmware version number. For details, see the " | + | * All units in one system must be the same type and firmware version; this includes same size, system voltage, and feature set. The type is indicated by the first four digits of the firmware version number. For details, see the " |
Line 14: | Line 17: | ||
- | First get experience with smaller systems. | + | These should all be considered essential before attempting design or installation. |
+ | First get experience with smaller systems. | ||
It is also recommended to hire an installer that has experience with these more complex Victron systems, for both the design and the commissioning. | It is also recommended to hire an installer that has experience with these more complex Victron systems, for both the design and the commissioning. | ||
Line 28: | Line 32: | ||
Line 39: | Line 43: | ||
+ | === Main text === | ||
- | For units in parallel: | + | For units in parallel: |
- | For DC, one fuse per phase is best. If a big single fuse is not available, use one fuse per unit. Same type of fuse due to same resistance. | + | With regards to AC fusing, each unit needs to be fused individually. Make sure to use the same type of fuse on each unit due to same resistance. Consider using mechanically connected fuses. |
- | Beware of phase rotation between the inverter and AC in. When wired in the wrong rotation, the system will not accept the mains input and only operates in inverter mode. In that case swap two phases | + | With regards to DC fusing, each unit needs to be fused individually. Make sure to use the same type of fuse on each unit due to same resistance. |
- | Note: Do not over-dimension the AC cabling. Using extra thick cabling has negative side effects.\\ | + | For both AC and DC fusing |
- | * Technical background: In a parallel system the AC current should be evenly distributed through all paralleled units. When the resistance in the cabling is very low, a small difference in resistance results in a large relative difference.\\ This results in bad current distribution.\\ An exaggerated example: | + | |
- | * Using 2 units (A and B) parallel | + | |
- | * Using the same 2 units in parallel with bad AC cabling one might end up with a total resistance | + | |
- | ==== A continuous, unbroken negative link must be maintained | + | Beware of phase rotation |
- | VE.Bus is not isolated on the MultiPlus range and Quattros. | + | === Warning against over-dimensioning the AC wiring === |
+ | Note: Do not over-dimension | ||
- | Therefore it is very important to prevent damage to the communications cards that the negative battery terminal of a Quattro remains continuous | + | Technical background: for a properly working parallel system, the AC current should be evenly distributed |
- | If units need to be isolated at both poles, or local wiring requirements demand double pole isolation | + | An exaggerated example: |
+ | * Using 2 units (A and B) parallel and using too good cabling, one might achieve a total resistance | ||
+ | * Using the same 2 units in parallel with, for the sake of this example underdimensioned AC cabling one might end up with a total resistance for Unit_A of 15Ω and a total resistance for Unit_B of 16Ω. This results in a much better current distribution (Unit_A will carry 1.066 times more current than Unit_A) even if the absolute difference in resistance is much bigger than in the previous example (1Ω vs 0.0001Ω). | ||
- | Double pole isolation | + | A side effect |
+ | === Delta configurations not supported === | ||
- | Theory and background information | + | For units in 3 phase configuration: |
+ | === Theory and background information | ||
+ | Wiring | ||
Line 77: | Line 89: | ||
Line 92: | Line 104: | ||
* All charger settings, such as absorption voltage, float voltage and max charge current.\\ (The maximum charge current is multiplied by the number of units in the system: in a 9 unit system set it to 50A to get a 450A maximum charge current.) | * All charger settings, such as absorption voltage, float voltage and max charge current.\\ (The maximum charge current is multiplied by the number of units in the system: in a 9 unit system set it to 50A to get a 450A maximum charge current.) | ||
* System frequency | * System frequency | ||
- | * Whether or not "Weak LOM" is used | ||
Line 102: | Line 113: | ||
Line 110: | Line 123: | ||
- | * The VE.Bus BMS and the Two-Signal BMS support Assistant also need to be loaded in each unit in the system. | + | * The VE.Bus BMS and the Two-Signal BMS support Assistant also need to be loaded in each unit in the system |
- | (nb: In some cases (depending on the choices made) slaves can be left out, the assistant | + | * For the [[https:// |
- | Tip: a quick way to load Assistants into each unit in the system is to save the settings after configuring the master in L1. Then open VEConfigure for another unit and load that file. VEConfigure will automatically adapt the Assistants for the slaves. (note: In some cases you might get some warnings. Please step through the assistant in that case.) | ||
Line 126: | Line 140: | ||
- | ===== DISQUS | + | ===== Training Video ===== |
- | ~~DISQUS~~ | + | |
ve.bus/manual_parallel_and_three_phase_systems.1569322489.txt.gz · Last modified: 2019-09-24 12:54 by guy_stewart
