ve.bus:manual_parallel_and_three_phase_systems [2026-02-12 13:10] – jpasopve.bus:manual_parallel_and_three_phase_systems [2026-03-04 08:34] (current) – [Communication wiring] guy_stewart
Line 98: Line 98:
 ===== Communication wiring ===== ===== Communication wiring =====
-  * All units must be daisy chained with the VE.Bus cable (RJ-45 cat5). The sequence for this is not important. Do not use terminators in the VE.Bus network.+  * All units must be daisy chained with the VE.Bus cable (RJ-45 Cat5 or better). The sequence for this is not important. Do not use terminators in the VE.Bus network.
   * The temperature sensor can be wired to any unit in the system. For a large battery bank it is possible to wire multiple temperature sensors. The system will use the one with the highest temperature to determine the temperature compensation.   * The temperature sensor can be wired to any unit in the system. For a large battery bank it is possible to wire multiple temperature sensors. The system will use the one with the highest temperature to determine the temperature compensation.
   * Wire the voltage sense on the master of L1.\\ (If the system has more than 1 AC input, connect it to the Master corresponding to the first AC input.) \\ All other units ignore their voltage sense input and receive the voltage sense value from the L1 master.   * Wire the voltage sense on the master of L1.\\ (If the system has more than 1 AC input, connect it to the Master corresponding to the first AC input.) \\ All other units ignore their voltage sense input and receive the voltage sense value from the L1 master.
 +  * [[https://www.victronenergy.com/live/ve.bus:ve.bus_network_interference|Further information on best practices for VE.Bus wiring]], can help with reducing VE.Bus errors caused by interference as system size increases.
 ===== Configuration ===== ===== Configuration =====
ve.bus/manual_parallel_and_three_phase_systems.1770901809.txt.gz · Last modified: by jpasop
