| ve.bus:manual_parallel_and_three_phase_systems [2022-11-24 13:48] – [Parallel, split- and three phase VE.Bus systems] mvader | ve.bus:manual_parallel_and_three_phase_systems [2026-03-04 08:34] (current) – [Communication wiring] guy_stewart | ||
| Line 1: | Line 1: | ||
| - | ====== Parallel, split- and three phase VE.Bus systems ====== | + | ====== Parallel, split- and three-phase VE.Bus systems ====== |
| - | This manual explains the details of designing, installing and configuring three-phase and parallel systems. It applies to components that use VE.Bus, for example MultiPlus, Quattro and some larger | + | This manual explains the details of designing, installing and configuring three-phase and parallel systems. It applies to components that use VE.Bus, for example, MultiPlus, Quattro and some larger |
| **IMPORTANT: | **IMPORTANT: | ||
| * Always update all units to the latest firmware version during commissioning of the system: ([[updating_firmware: | * Always update all units to the latest firmware version during commissioning of the system: ([[updating_firmware: | ||
| - | * Note that some parts of the description below apply only firmware version 400 and later. | + | * Note that some parts of the description below apply only to firmware version 400 and later. |
| - | * All units in one system must be the same type and firmware version, this includes same size, system voltage, and feature set. The type is indicated by the first four digits of the firmware version number. For details, see the " | + | * All units in one system must be the same type and firmware version; this includes same size, system voltage, and feature set. The type is indicated by the first four digits of the firmware version number. For details, see the " |
| - | * Specify with your [[https:// | + | * Specify with your [[https:// |
| + | * All parallel units in the same phase should have matching compatibility ID letter. See information below. | ||
| * The same number of units need to be installed on each phase. An example to clarify: 3 units on L1, 3 on L2, and 3 on L3 is OK. But 2 on L1, 3 on L2 and 3 on L3 is not OK. The only way such non-symmetrical installation is supported is when using no monitoring at all, or a Digital Multi Control. Combining such system with any other monitoring device, such as the VE.Bus Smart Dongle or a GX device like the Cerbo is not supported. Numbers and information shown on the GX device as well as VRM portal will or can be wrong, and controlling the system, for example setting input current limits will not always work properly either. | * The same number of units need to be installed on each phase. An example to clarify: 3 units on L1, 3 on L2, and 3 on L3 is OK. But 2 on L1, 3 on L2 and 3 on L3 is not OK. The only way such non-symmetrical installation is supported is when using no monitoring at all, or a Digital Multi Control. Combining such system with any other monitoring device, such as the VE.Bus Smart Dongle or a GX device like the Cerbo is not supported. Numbers and information shown on the GX device as well as VRM portal will or can be wrong, and controlling the system, for example setting input current limits will not always work properly either. | ||
| + | * MultiPlus-II 8k, 10k, and 15k models can only be connected in parallel if an external AC transfer switch is used. For more information see the [[https:// | ||
| * While VE.Bus System Configurator allows setting up a system using Multis (each having a single AC input), that is configured to have multiple separate AC inputs, such system is not supported by GX devices. | * While VE.Bus System Configurator allows setting up a system using Multis (each having a single AC input), that is configured to have multiple separate AC inputs, such system is not supported by GX devices. | ||
| + | * This information does __not__ apply to the Multi RS and Inverter RS models, which use a VE.Can interface (not VE.Bus) see the RS product manuals for specific information on programming them for three phase. | ||
| + | ===== Compatibility IDs explained ===== | ||
| + | The **compatibility ID** denotes which devices can be combined in a VE.Bus system.\\ This ID can be found on the stickers of the units.< | ||
| + | * Make sure that the 4-digit number in the compatibility ID of all units in the VE.Bus system is identical . | ||
| + | * Make sure that units in a single phase (so parallel units) have an identical letter in the compatibility ID. | ||
| + | Note: The 4-digit number in the compatibility ID does not necessarily represent the firmware version of the unit itself. For instance a MultiPlus-II 24/ | ||
| ===== Warning ===== | ===== Warning ===== | ||
| Line 50: | Line 62: | ||
| For units in parallel: Both the DC and AC wiring needs to be symmetrical per phase: use the same length, type and cross-section to every unit in the phase. To make this easy, use a bus-bar or power-post before and after the inverter/ | For units in parallel: Both the DC and AC wiring needs to be symmetrical per phase: use the same length, type and cross-section to every unit in the phase. To make this easy, use a bus-bar or power-post before and after the inverter/ | ||
| - | With regards to AC fusing, each unit needs to be fused individually. Make sure to use the same type of fuse on each unit due to same resistance. Consider using mechanically connected fuses. | + | With regards to AC fusing, each unit needs to be fused individually. Make sure to use the same type of fuse on each unit due to same resistance. Consider using mechanically connected fuses, so that if one trips, they all trip - leading to a clear fault. |
| With regards to DC fusing, each unit needs to be fused individually. Make sure to use the same type of fuse on each unit due to same resistance. | With regards to DC fusing, each unit needs to be fused individually. Make sure to use the same type of fuse on each unit due to same resistance. | ||
| Line 86: | Line 98: | ||
| ===== Communication wiring ===== | ===== Communication wiring ===== | ||
| - | * All units must be daisy chained with the VE.Bus cable (RJ-45 | + | * All units must be daisy chained with the VE.Bus cable (RJ-45 |
| * The temperature sensor can be wired to any unit in the system. For a large battery bank it is possible to wire multiple temperature sensors. The system will use the one with the highest temperature to determine the temperature compensation. | * The temperature sensor can be wired to any unit in the system. For a large battery bank it is possible to wire multiple temperature sensors. The system will use the one with the highest temperature to determine the temperature compensation. | ||
| * Wire the voltage sense on the master of L1.\\ (If the system has more than 1 AC input, connect it to the Master corresponding to the first AC input.) \\ All other units ignore their voltage sense input and receive the voltage sense value from the L1 master. | * Wire the voltage sense on the master of L1.\\ (If the system has more than 1 AC input, connect it to the Master corresponding to the first AC input.) \\ All other units ignore their voltage sense input and receive the voltage sense value from the L1 master. | ||
| + | * [[https:// | ||
| ===== Configuration ===== | ===== Configuration ===== | ||
| Line 103: | Line 116: | ||
| * All charger settings, such as absorption voltage, float voltage and max charge current.\\ (The maximum charge current is multiplied by the number of units in the system: in a 9 unit system set it to 50A to get a 450A maximum charge current.) | * All charger settings, such as absorption voltage, float voltage and max charge current.\\ (The maximum charge current is multiplied by the number of units in the system: in a 9 unit system set it to 50A to get a 450A maximum charge current.) | ||
| * System frequency | * System frequency | ||
| - | * Whether or not "Weak LOM" is used | ||
| The following settings need to be made in the master of each phase: | The following settings need to be made in the master of each phase: | ||
| * Inverter output voltage | * Inverter output voltage | ||
| Line 110: | Line 122: | ||
| * PowerAssist settings | * PowerAssist settings | ||
| * Accept wide input frequency range on/off | * Accept wide input frequency range on/off | ||
| + | * Weak AC input on/off | ||
| The following settings need to made in each unit in the system: | The following settings need to made in each unit in the system: | ||
| * Country / grid code standard and other grid related values (AC high/ low values) | * Country / grid code standard and other grid related values (AC high/ low values) | ||
| Line 136: | Line 149: | ||
| * [[https:// | * [[https:// | ||
ve.bus/manual_parallel_and_three_phase_systems.1669297690.txt.gz · Last modified: by mvader
