ve.bus:manual_parallel_and_three_phase_systems [2019-12-09 13:10] – [Configuration] mvader | ve.bus:manual_parallel_and_three_phase_systems [2019-12-13 03:32] – Add reminder that DVCC overrides the charger settings (just as it does in single unit systems) simonhackett | ||
Line 104: | Line 104: | ||
A quick way to make settings in all units is the 'send to all units' feature. You'll see the option after making the changes to the first unit. | A quick way to make settings in all units is the 'send to all units' feature. You'll see the option after making the changes to the first unit. |
