ve.bus:manual_parallel_and_three_phase_systems [2019-10-27 02:23] – [A continuous, unbroken negative link must be maintained between all units] guystewart | ve.bus:manual_parallel_and_three_phase_systems [2019-11-17 11:35] – [Warning] guy_stewart | ||
Line 17: | Line 17: | ||
This should be considered essential before attempting design or installation. | This should be considered essential before attempting design or installation. | ||
- | First get experience with smaller systems. | + | First get experience with smaller systems. |
It is also recommended to hire an installer that has experience with these more complex Victron systems, for both the design and the commissioning. | It is also recommended to hire an installer that has experience with these more complex Victron systems, for both the design and the commissioning. |
