ve.bus:manual_parallel_and_three_phase_systems [2019-01-22 10:16] – external edit 127.0.0.1 | ve.bus:manual_parallel_and_three_phase_systems [2020-04-30 00:59] – [DC and AC wiring] mleeftink | ||
====== Parallel and three phase VE.Bus systems ====== | ====== Parallel and three phase VE.Bus systems ====== | ||
- | This manual explains the details of designing, installing and configuring three-phase and parallel systems. It applies to components that use VE.Bus, for example | + | This manual explains the details of designing, installing and configuring three-phase and parallel systems. It applies to components that use VE.Bus, for example |
- | * Always update all units to the latest 400 firmware version([[updating_firmware: | + | * Always update all units to the latest 400 firmware version ([[updating_firmware: |
* Note that some parts of the description below apply only to 4xx firmwares. | * Note that some parts of the description below apply only to 4xx firmwares. | ||
- | * All units in one system must be the same type and firmware version. The type is indicated by the first four digits of the firmware version number. For details, see the " | + | * All units in one system must be the same type and firmware version, this includes same size, system voltage, and feature set. The type is indicated by the first four digits of the firmware version number. For details, see the " |
Line 16: | Line 17: | ||
This should be considered essential before attempting design or installation. | This should be considered essential before attempting design or installation. | ||
- | First get experience with smaller systems. | + | First get experience with smaller systems. |
It is also recommended to hire an installer that has experience with these more complex Victron systems, for both the design and the commissioning. | It is also recommended to hire an installer that has experience with these more complex Victron systems, for both the design and the commissioning. | ||
Line 38: | Line 39: | ||
Line 44: | Line 44: | ||
- | For units in parallel: | + | For units in parallel: |
- | For DC, one fuse per phase is best. If a big single fuse is not available, use one fuse per unit. Same type of fuse due to same resistance. | + | With regards to AC fusing, each unit needs to be fused individually. Both on its AC-out and AC-in. Multiple circuit breakers which are mechanically connected together |
- | Beware of phase rotation between the inverter and AC in. When wired in the wrong rotation, the system will not accept the mains input and only operates in inverter mode. In that case swap two phases to correct it. | + | With regards to DC fusing, each unit needs to be fused individually. Make sure to use the same type of fuse on each unit due to same resistance. |
+ | Beware of phase rotation between the inverter and AC in. When wired in a rotation | ||
Note: Do not over-dimension the AC cabling. Using extra thick cabling has negative side effects.\\ | Note: Do not over-dimension the AC cabling. Using extra thick cabling has negative side effects.\\ | ||
Line 55: | Line 59: | ||
* Using the same 2 units in parallel with bad AC cabling one might end up with a total resistance for Unit_A of 15Ω and a total resistance for Unit_B of 16Ω. This results in a much better current distribution (Unit_A will carry 1.066 times more current than Unit_A) even if the absolute difference in resistance is much bigger than in the previous example (1Ω vs 0.0001Ω). | * Using the same 2 units in parallel with bad AC cabling one might end up with a total resistance for Unit_A of 15Ω and a total resistance for Unit_B of 16Ω. This results in a much better current distribution (Unit_A will carry 1.066 times more current than Unit_A) even if the absolute difference in resistance is much bigger than in the previous example (1Ω vs 0.0001Ω). | ||
- | Theory and background information | + | For units in 3 phase configuration: |
+ | ==== A continuous, unbroken negative link must be maintained between all units ==== | ||
+ | VE.Bus is not isolated on the MultiPlus range and Quattros. | ||
+ | Therefore it is very important to prevent damage to the communications cards that the negative battery terminal of a Quattro remains continuous between units as long as the VE.Bus cable that connects the multiple units is connected. | ||
+ | If units need to be isolated at both poles, or local wiring requirements demand double pole isolation for each unit, the communications cables must be removed first AND appropriate safety signage needs to clearly explain this. | ||
+ | Double pole isolation of the system is allowed (and sometimes required), as long as it at the battery connection end of the DC bus, and the Multis/ | ||
+ | ==== Theory and background information | ||
+ | wiring is further explained in these presentations: | ||
+ | * [[https:// | ||
Line 64: | Line 87: | ||
+ | Note: Special considerations exist before initial power-up for large systems using Redflow batteries: [[https:// | ||
In the [[https:// | In the [[https:// | ||
* Up to three units: use VE.Bus Quick Configure | * Up to three units: use VE.Bus Quick Configure | ||
Line 76: | Line 102: | ||
- | * Power Assist | + | * PowerAssist |
Note that AES is only operational in stand-alone systems. Not in parallel and multi-phase systems. | Note that AES is only operational in stand-alone systems. Not in parallel and multi-phase systems. | ||
==== Virtual switch ==== | ==== Virtual switch ==== | ||
A unique virtual switch configuration can be configured for each unit in the system. With the exception of the Ignore AC input function: configure that in the master of L1. | A unique virtual switch configuration can be configured for each unit in the system. With the exception of the Ignore AC input function: configure that in the master of L1. | ||
* The VE.Bus BMS and the Two-Signal BMS support Assistant also need to be loaded in each unit in the system. | * The VE.Bus BMS and the Two-Signal BMS support Assistant also need to be loaded in each unit in the system. | ||
- | (nb: In some cases (depending on the choices made) slaves can left out, the assistant will notify you about this.) | + | (nb: In some cases (depending on the choices made) slaves can be left out, the assistant will notify you about this.) |
- | Tip: a quick way to load Assistants into each unit in the system is to save the settings after configuring the master in L1. Then open VEConfigure for an other unit and load that file. VEConfigure will automatically adapt the Assistants for the slaves. (note: In some cases you might get some warnings. Please step through the assistant in that case.) | + | Tip: a quick way to load Assistants into each unit in the system is to save the settings after configuring the master in L1. Then open VEConfigure for another |
Line 108: | Line 137: | ||
- | ===== DISQUS | + | ===== Training Video ===== |
- | ~~DISQUS~~ | + | |
