ve.bus:manual_parallel_and_three_phase_systems [2019-01-22 10:16] – external edit 127.0.0.1 | ve.bus:manual_parallel_and_three_phase_systems [2019-01-24 23:01] – [Parallel and three phase VE.Bus systems] guy_stewart | ||
Line 7: | Line 7: | ||
* Always update all units to the latest 400 firmware version([[updating_firmware: | * Always update all units to the latest 400 firmware version([[updating_firmware: | ||
* Note that some parts of the description below apply only to 4xx firmwares. | * Note that some parts of the description below apply only to 4xx firmwares. | ||
- | * All units in one system must be the same type and firmware version. The type is indicated by the first four digits of the firmware version number. For details, see the " | + | * All units in one system must be the same type and firmware version, this includes same size, system voltage, and feature set. The type is indicated by the first four digits of the firmware version number. For details, see the " |
===== Warning ===== | ===== Warning ===== |
