ve.bus:grid-codes-and-loss-of-mains-detection [2018-08-22 12:43] – [LOM detection Type A and Type B] pba | ve.bus:grid-codes-and-loss-of-mains-detection [2019-01-22 10:16] – external edit 127.0.0.1 | ||
Line 78: | Line 78: | ||
Some, bigger or better quality generators, will be able to work with LOM **Type B**. For other less stable generators it will be required to disable LOM entirely. In that case make the installation such that it is still safe: no simple extensions cords, use enclosed wiring cabinets with warnings on the outside and/or an external ENS. | Some, bigger or better quality generators, will be able to work with LOM **Type B**. For other less stable generators it will be required to disable LOM entirely. In that case make the installation such that it is still safe: no simple extensions cords, use enclosed wiring cabinets with warnings on the outside and/or an external ENS. | ||
+ | More information here: https:// | ||
==== Q4: I use ESS, but have disabled feed-back, is a grid-code still required? ==== | ==== Q4: I use ESS, but have disabled feed-back, is a grid-code still required? ==== | ||
A: Yes, also in this case LOM is required to make for a safe and also local regulations compliant system. Running ESS with disabled-feed-back is still not the same as using a Multi in its default configuration without ESS. | A: Yes, also in this case LOM is required to make for a safe and also local regulations compliant system. Running ESS with disabled-feed-back is still not the same as using a Multi in its default configuration without ESS. | ||
ve.bus/grid-codes-and-loss-of-mains-detection.txt · Last modified: 2022-10-31 23:41 by mvader
