ve.bus:grid-codes-and-loss-of-mains-detection [2017-12-08 12:08] – mvader | ve.bus:grid-codes-and-loss-of-mains-detection [2019-01-21 11:12] – [DISQUS] ictbeheer | ||
Line 8: | Line 8: | ||
The exact requirements differ widely between the countries. For example the normal Multis, Quattros and MultiCompacts are certified for use in the UK. For other countries, Germany for example, only the MultiGrid is and can be certified to be used without having to add more external anti-islanding safety devices (ENS). And in yet other countries an external ENS is required and/or the inverter/ | The exact requirements differ widely between the countries. For example the normal Multis, Quattros and MultiCompacts are certified for use in the UK. For other countries, Germany for example, only the MultiGrid is and can be certified to be used without having to add more external anti-islanding safety devices (ENS). And in yet other countries an external ENS is required and/or the inverter/ | ||
- | ===== 2. Loss of mains detection (L.O.M.) ===== | + | ===== 2. Loss of mains detection (LOM) ===== |
- | ==== What is L.O.M. | + | ==== What is LOM detection? ==== |
- | L.O.M. | + | LOM is an automatic process that detects a change and so loss of the mains/ |
- | ==== Why is L.O.M. | + | ==== Why is LOM detection required? ==== |
- | The purpose of L.O.M is to detect that the Multi is no longer connected to the mains. Be that a generator or the grid. In such case, the Multi needs to open its back-feed relay. Not doing that would be unsafe. Imagine an electrician working on the street, and disconnecting a house. He then needs to be able to safely work on the wiring from the house. | + | The purpose of LOM is to detect that the Multi is no longer connected to the mains. Be that a generator or the grid. In such case, the Multi needs to open its back-feed relay. Not doing that would be unsafe. Imagine an electrician working on the street, and disconnecting a house. He then needs to be able to safely work on the wiring from the house. |
- | ==== How does LO.M. detection relate to overload shutdowns? ==== | + | ==== How does LOM detection relate to overload shutdowns? ==== |
To detect a loss of mains, the inverter/ | To detect a loss of mains, the inverter/ | ||
Line 27: | Line 27: | ||
LOM detection comes in two flavours: **Type A** and **Type B**. | LOM detection comes in two flavours: **Type A** and **Type B**. | ||
- | **Type A** is the strongest form LOM detection, which results | + | **Type A** is the strongest form of LOM detection |
- | **Type B** has a more soft approach. Resulting in a slightly longer detection time. Still acceptable in several countries | + | **Type B** has a more soft approach |
+ | On generators, and also with installations having | ||
For generators on which also **Type B** does not work, see Disabling LOM. | For generators on which also **Type B** does not work, see Disabling LOM. | ||
Line 77: | Line 78: | ||
Some, bigger or better quality generators, will be able to work with LOM **Type B**. For other less stable generators it will be required to disable LOM entirely. In that case make the installation such that it is still safe: no simple extensions cords, use enclosed wiring cabinets with warnings on the outside and/or an external ENS. | Some, bigger or better quality generators, will be able to work with LOM **Type B**. For other less stable generators it will be required to disable LOM entirely. In that case make the installation such that it is still safe: no simple extensions cords, use enclosed wiring cabinets with warnings on the outside and/or an external ENS. | ||
+ | More information here: https:// | ||
==== Q4: I use ESS, but have disabled feed-back, is a grid-code still required? ==== | ==== Q4: I use ESS, but have disabled feed-back, is a grid-code still required? ==== | ||
A: Yes, also in this case LOM is required to make for a safe and also local regulations compliant system. Running ESS with disabled-feed-back is still not the same as using a Multi in its default configuration without ESS. | A: Yes, also in this case LOM is required to make for a safe and also local regulations compliant system. Running ESS with disabled-feed-back is still not the same as using a Multi in its default configuration without ESS. | ||
ve.bus/grid-codes-and-loss-of-mains-detection.txt · Last modified: 2022-10-31 23:41 by mvader
