ve.bus:grid-codes-and-loss-of-mains-detection [2022-10-31 15:50] – mvader | ve.bus:grid-codes-and-loss-of-mains-detection [2022-10-31 23:41] (current) – [2.8 Grid codes and Type A and Type B LOM] mvader | ||
Line 25: | Line 25: | ||
To detect a loss of mains, the inverter/ | To detect a loss of mains, the inverter/ | ||
- | When connected to a generator, or to a grid with a long extension cable or long ‘last mile’ cable, the impedance of the grid becomes much higher and the pushing and pulling on the grid will have a certain affect on its voltage. As a result the inverter/ | + | When connected to a generator, or to a grid with a long extension cable or long ‘last mile’ cable, the impedance of the grid becomes much higher and the pushing and pulling on the grid will have a certain affect on the grid voltage. As a result the inverter/ |
==== 2.4 How does LOM detection relate to passthru? ==== | ==== 2.4 How does LOM detection relate to passthru? ==== | ||
Line 96: | Line 96: | ||
* Grid codes using Type A: VEConfigure lets you override that to Type B and/or disabling LOM. | * Grid codes using Type A: VEConfigure lets you override that to Type B and/or disabling LOM. | ||
* Grid codes using Type B: VEConfigure lets the installer override it to disabling LOM only. | * Grid codes using Type B: VEConfigure lets the installer override it to disabling LOM only. | ||
+ | * Grid codes using " | ||
ve.bus/grid-codes-and-loss-of-mains-detection.txt · Last modified: 2022-10-31 23:41 by mvader
